2020 GT500 spindles and suspension questions.
Decible
Georgia
Sam
2023 Mach 1 HP
On my last car, I did a complete GT to GT350 brake swap. For the front, I had to install a custom made bracket to the GT knuckle so the GT350 caliper could mount to it. Everything else stayed stock GT.
For the rear, I had to swap the e-brake cables (due to drum style e-brake), rear LCA (due to the sensor hole location), and then install the GT350 e-brake assembly, along with an e-brake cable bracket to complete the install. The wheel bearing bolts are now also slightly longer to accommodate the width of the e-brake assembly. Everything else stayed stock GT.
Yeah I know the kit uses a bracket, I think the op was asking what it would take to run the R front knuckle on a GT
I’ve wondered as well what it would take to run the R front knuckle as well. I’ve never been able to get a good answer 😂🤷🏼‍♂️
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2022 F150 PowerBoost
It will require using GT 350 caliper. There is a bracket that will make the 350 caliper mount to the GT knuckle, but there is no way to make the GT caliper work with the GT 350 knuckle.
Decible
Georgia
Sam
2023 Mach 1 HP
Yeah I’m referring to running the R knuckle on. GT with 350 brakes
Jmeo
You said member ;)
Massachusetts
Jaime
Decible
Georgia
Sam
2023 Mach 1 HP
My Spidey senses think it should work fine.
Mine says it should work as well but…this is ford we are talking about 🤷🏼‍♂️
GTFORMULA
GTFORMULA
FLORIDA
2014 Grey gt500 pp, recaros, nav
Just to clear some stuff up, I own a 2020 GT500. I'm looking to go down in brake size and weight for drag racing. So I want to swap all the calipers, rotors, and probably spindles to a normal GT setup. I already have Aerospace drag rear brakes and stock 2018 GT front calipers and rotors from other builds.
Decible
Georgia
Sam
2023 Mach 1 HP
So I’ve got some more info. This applies for going in the 350 to GT way. I spoke to a suspension engineer from a company that builds race parts. The tapers in the knuckle for the 350 differ from the GT. He also said he believes the lca’s for the 350 are a little longer as well. My overall thinking is everything that attaches the knuckle to the car needs to be changed. Track width is also going to change without the use of custom parts to shorten up the lca’s to the standard GT length.
This is doable but it’s not simple
Jmeo
You said member ;)
Massachusetts
Jaime
Not sure what he means by tapers, but the LCA’s are not longer. I spent some time comparing them when I swapped to 350 breaks, the only difference in the rears between the two is the drum style e-brake on the 350. This assembly pushes the rear wheel roughly 5/16” out, which is why the location of the sensors moved. So in the end the wheels are pushed out, but not because the LCA is any longer.
Decible
Georgia
Sam
2023 Mach 1 HP
Jamie, the engineer was referring to the fronts not the rears
ps - taper is on the stud is what he is referencing
Jmeo
You said member ;)
Massachusetts
Jaime
Oh, I saw LCA and my mind went straight to the rear, sorry.
Decible
Georgia
Sam
2023 Mach 1 HP
Lmao!!! I did the same thing when the engineer emailed me back!! I was like naw man on the fronts. And he was like the front have lower control arms too 🥴 I was like riiiiiight my bad 🤦🏼‍♂️
Flyhalf
CA
www.youtube.com
Alessandro
Mustang GT 18 10speed auto PP1 , GT500 '21
The radial mount on the GT350/GT500 spindles are geared towards big brakes. I'd stick with the GT hardware and any number of parts that are readily available to do what you are looking for.
Do you have any info about a AP RACING KIT SWAP in a gt500?
Really considering it to be able to use 18 for track purposes.
Epiphany
Global
I like to disassemble things.
Tonymustang302
Chicagoland burbs, IL
Tony
2017 Turbo GT, 2019 GT350 racecar, 2021 GT500
I see you 👀
