It takes more than 11.5 qts. After dumping a full case in, it still wasn't full. That is the norm.Thank you sir! The plate idea is BRILLIANT!
I typically do that too, but with trying to capture everything on video, I forgot it. I suspect it makes no difference though... I didnāt see any disruption in flow. The oil came out in a solid stream. If there was a vacuum, it would have been chugging, or whatever you call it when air goes back in to displace the leaving liquid.
I was surprised at the volume of oil that came out. I knew the car took 11.5 quarts, but Iāve never drained that much out of a vehicle before.
Good to know. I havenāt driven the car yet post oil change. Iāll check the oil level.It takes more than 11.5 qts. After dumping a full case in, it still wasn't full. That is the norm.
Its near the top end of the hash marks, but not full. I'm not adding any more than 12 qts. I have about 1,000 miles on it now. I changed the oil at 500. The oil level has been consistent. I have not burned any oil so far, so I am ok with leaving the level where it is at.I'm thinking after letting it sit overnight, 11.5 its will probably put it in the hash marks.
Thats not perfect.Just went to the garage and checked my oil level... it looks perfect after adding the 11.5 quarts recommended in the manual. It is squarely in the middle of the hash marks.
Yea thats kinda what I would of expected Goose. I remember reading that they say, when it falls anywhere within the hashmarks, do not add oil.Just went to the garage and checked my oil level... it looks perfect after adding the 11.5 quarts recommended in the manual. It is squarely in the middle of the hash marks.
I believe it said that when checking the oil during periodic inspectionsYea thats kinda what I would of expected Goose. I remember reading that they say, when it falls anywhere within the hashmarks, do not add oil.
It's apparent you're a very thorough guy so I'll remember this thread when mine comes due. Thanks for the update
Makes no difference. The driverās side valve cover is open to the air filter. So itās not possible to create a vacuum in the oil pan.Jaime and Tim, I have always cracked open the filler cap before opening the drain to prevent a vacuum on all my vehicles. Good idea, bad or don't matter?
Thoughts?
For me it falls right in line with never putting a battery directly on the concrete. I donāt have to, but I do anyway. Lasting side effects of being raised by a life long career mechanic. Iām sure I picked up many a mechanics tale, but I appreciate them just the same. I will also pass them sown to my kids, like I know what Iām doing, lol.Makes no difference. The driverās side valve cover is open to the air filter. So itās not possible to create a vacuum in the oil pan.
Great video. Thanks for posting.In this video, I show how to change the oil on the 2020 GT500, how to deal with the cartridge style oil filter, how to reset the oil life counter as well as a bonus of making my low CFTP compatible with my 2-post lift!
The marks on the drain plug and filter housing were both factory marks. For my vehicles that have vertical oil filters, I pre-fill them with oil. This one is on a slant. I did not pre-fill it, but I did watch the oil pressure as I started the car and it immediately came up.Great video. Thanks for posting.
One question. On the drain plug, did you make the yellow mark or is that done at the factory?
Never mind. After watching the video to the end you mentioned factory marks on the filter canister so I assume the drain plug marks are factory as well.
Did you pre-fill the canister with oil to get some oil in the filter? I am thinking when I do mine, I will put the filter in the canister, then fill with oil and let it soak a bit. Then quickly mount the filter to the block and put the canister on. I'm sure a little oil will drip off but better to have a pre-filled filter?
Thoughts?
Really appreciated this video today. First at home oil change and was able to have everything ready thanks to your video.In this video, I show how to change the oil on the 2020 GT500, how to deal with the cartridge style oil filter, how to reset the oil life counter as well as a bonus of making my low CFTP compatible with my 2-post lift!
