fpa1974
I definitely would not worry much. IMO, like others said it is something on the accessory belt drive. After having an E46 BMW that was eating idler pulleys for lunch, this type of noise is very familiar
Nearly all Fords use those same pulleys. I keep a couple on my shelf as it seems Iām replacing one every few months on something. Just keep driving it until you hear it again. Open the hood next time and check closer.This is good advice. I diagnosed a bad water pump this way. And agreed with the other. Definitely not the oil pump - thatās at the front. If removing the belt doesnāt change it, it might be related to the flywheel. But agreed, sounds like a pulley
Thank you guys for sharing your thoughts. Itās comforting to hear that none of you think itās the oil pump. with any luck, it wonāt happen again.
if it does, Iāll do a better job of not panicking and looking closer.
im gonna keep driving it as much as possible before the winter hits and see what happens.
im on my way home from work now, Iām going to stop by my local dealers and show them the videos for a little more peace of mind.
ill update later.
