2019 GT350R - tramlining , any suggestions?
Discussion in 'Shelby GT350 Mustang' started by mzangari1234, Aug 26, 2019.
  1. JAJ
    JAJ Well-Known Member
    Vehicle(s):
    2016 GT350 Track Pack
    Apr 9, 2016
    Vancouver BC
    807
    495
    0   0   0
    Fronts are A/S-3+'s in 275/40x19 and rears are A/S Plus N-Spec in 285/40x19. They work fine together but because they aren't exactly the same, the TR search engine won't display them.
    I was fortunate enough to get a pair of 285/40x19 A/S-3's (without the "+") back in 2016 and I have them on the rear of my car on OEM aluminum rims.
    These are the smallest width tires that will work on the GT350R OEM rims. If you pick up a set of GT350 OEM rims, you can run 265/40x19 and 275/40x19 both in A/S-3+. They are not recommended by Michelin for the wider "R" rims.
    IronSooner and J-Stang like this.
  2. tracktardicus
    tracktardicus Well-Known Member
    Vehicle(s):
    2017 GT350R
    Feb 13, 2018
    Denver CO
    201
    117
    0   0   0
    I'm running the Pilot SPort 4S 305/30/19-sized tires on all 4 corners for street use, and the tramlining is gone, even with -2.5 degree camber dialed in.
  3. Droopy1592
    Droopy1592 Well-Known Member
    First Name:
    Damien
    Vehicle(s):
    2017 GT350
    Apr 11, 2019
    Atlanta
    264
    96
    0   0   0
    The MPSS and Cup tires tramline in sizes this wide (295+). I had my alignment checked and the right front was dialed down to -1.5 camber (was at -2) and left was at -1.5. It cut down on the tram lining substantially but it’s still there, it’s the nature of this beast. Also, putting steering in comfort mode also cuts back the severity somewhat noticeably. If you want it to be reduced more, try a different tire. I saw a post somewhere that mentioned some suspension parts that could be the culprit.
  4. 03reptile
    03reptile Well-Known Member
    Vehicle(s):
    2019 Shelby GT350
    Mar 6, 2019
    148
    125
    0   0   0
    Above info is exactly what my racing tire man recommended for the best performance and least effect on speedo error. The rears are a Porsche spec tire and run damned wide. They are wider than the 305 Cup 2's.
  5. stanglife
    stanglife Well-Known Member
    First Name:
    Jeff
    Vehicle(s):
    1993 Coyote Coupe
    Jul 6, 2014
    5,143
    3,026
    0   0   0
    Tire compound, tire pressure, tire size and alignment. I'd skip any kind of brace = added weight.
  6. nastang87xx
    nastang87xx Well-Known Member
    Vehicle(s):
    Jun 5, 2015
    Wisconsin
    6,132
    3,594
    0   0   0
    Yeah I kinda just deal with it. That type of brace I don't think really is going to do anything on track or autocross.
  7. treefiddysnek
    treefiddysnek Member
    Vehicle(s):
    2017 GT350R
    Aug 25, 2019
    Southeastern USA
    I'm running these same tires on my GT350R, except I'm running staggered with 325s in the back. They completely eliminated the tramlining I was experiencing with the cup 2s, and they have a longer tread life on the street. They were definitely worth the purchase.
    stanglife likes this.
  8. stanglife
    First Name:
    Jeff
    Vehicle(s):
    1993 Coyote Coupe
    Jul 6, 2014
    5,143
    3,026
    0   0   0
    Same 4S on mine = almost zero tramlining.
    mzangari1234 likes this.
  9. Doskiller
    Doskiller Well-Known Member
    Vehicle(s):
    2018 GT350R
    Nov 30, 2015
    Virginia Beach, VA
    161
    61
    0   0   0
    Pilot Sport 4S tires solved all my tramlining issues on both my 350 and 350R. I used that brace on my 350 and it did exactly nothing but add weight .......... ;-)
  10. RJay
    RJay Well-Known Member
    First Name:
    Randy
    Vehicle(s):
    2019 GT350
    May 24, 2019
    Phoenix
    325
    232
    0   0   0
    I must say I love my MPSS's! Drove straight from the dealer to the tire shop for a swap - drive them daily and could not be happier - consistently average 22-23 MPG. Two great things: they don't vacuum up every rock on the road and you can buy 295/35ZR19's and 305/35ZR19's directly from Tire Rack (Base GT350).
    03reptile, Voodoo Velocity and key01 like this.
  11. Niz55
    Niz55 Well-Known Member
    Vehicle(s):
    17 GT350
    May 10, 2015
    Us
    3,577
    1,128
    Rating:
    100%
    6   0   0
    Next tire set I am doing 215-45-19 up front. That should take care of it and fix the problem.
    svttim, ClayDee and Sletcher like this.
  12. BmacIL
    BmacIL Enginerd
    Vehicle(s):
    2015 Guard GT Base, M/T
    Sep 21, 2014
    Naperville, IL
    14,199
    8,151
    Garage Profiles:
    Rating:
    100%
    3   0   0
    It's tires.
    03reptile likes this.
  13. OP
    mzangari1234
    mzangari1234 Well-Known Member
    First Name:
    Michael
    Vehicle(s):
    2019 Shelby GT350R
    Aug 6, 2019
    New york
    Thanks all - sounds like my only option is new tires - appreciate the responses!
  14. jgruben1134
    jgruben1134 Well-Known Member
    First Name:
    Jeff
    Vehicle(s):
    2019 GT Premium PP2 Velocity Blue "Moby"
    Jul 18, 2019
    Atlanta
    77
    62
    0   0   0
    Yep, definitely tires. I test drove several cars before buying my PP2. None of the non-PP2 cars had this issue, but mine, with the Cup 2's does. It's manageable, but its definitely there. I think I'll be going to PS4s when the time comes.
  15. svttim
    svttim Well-Known Member
    Vehicle(s):
    2019 GT350R
    Mar 5, 2016
    Wisconsin
    777
    604
    0   0   0
    When the dealer installed my caster camber plates I told them to align it to street specs. Im not sure what specs they used but, no tramline with the SC2. Easy to drive and, it worked fine on track as well although Im sure not ideal
Loading...
Share This Page
