87rodman
- Aug 26, 2019
- detroit,mi
- Rodney
- Bunch of Fords
Anybody?
I have no idea what KM and ICP are.I have a 19 Bullitt here at the dealership that I need to get the KM off the big readout in the ICP..It was a Maple leaf car and the customer is asking if I can swap the two readouts..I tried IDS and there is nothing..I can as-built data reprogram the icp with a vin from a US car maybe?Forscan?
Thanks for any help you guys may have..
I am no expert here so I can offer some or little help. if you are trying to get the mileage out of the IPC then you won't be able to as this information is held in the PCM (powertrain control module). Are you trying to a digital dash swap out? If the only reason you are doing this is to get a MPH speedometer you can enable the MPH on the digital dash to show both km/h and mph. It's a small adjustment to get used to as the km/h reading would be larger than the mph.I have a 19 Bullitt here at the dealership that I need to get the KM off the big readout in the ICP..It was a Maple leaf car and the customer is asking if I can swap the two readouts..I tried IDS and there is nothing..I can as-built data reprogram the icp with a vin from a US car maybe?Forscan?
LOL..yep..Eyes are old too..He has dyslexic fingers. He meant IPC and KM is kilometres.![]()
I would ensure you have the original as-built for the Canadian car before doing the IPC changes to the US. I think there is a link in the forums where you can get the original as-built data specific to your VIN number.I may use as-built data from a US Bullitt mustang same year and options and do a reprogram on the IPC..Its gotta be software..
Ronin47[/QUOT
I can pull it right from DOESII from ford..I'm changing the Canadian Bullitt so swapping vins in the IDS should be cool..I'm more worried about a tech down the road doing work might run into a problem..I'm trying it tonight after work, so im crossing my fingers..I can always reprogram it back to stock..
Sorry, mine was set to work when I picked it up. I don’t believe there’s a setting to turn either options on/off, but I could be wrong.I'm trying to figure out how to enable the outside air temp and to show what song is playing on the digital dash... I see pics of other peoples doing this but mine doesn't have the option it seems... are there forscan values for this?
See that’s confusing lolSorry, mine was set to work when I picked it up. I don’t believe there’s a setting to turn either options on/off, but I could be wrong.
My memory doesn’t serve me well and I can’t double check as the beast is in its winter slumber. Have you gone through the dash settings to see if there was a setting there? In FORScan you have to check the IPC config if it’s there. I doubt you will see any thing in the APIM or BCM modules.I'm trying to figure out how to enable the outside air temp and to show what song is playing on the digital dash... I see pics of other peoples doing this but mine doesn't have the option it seems... are there forscan values for this?
