mainemaine89
Im having a hard time connecting to forscan it keep saying ELM not found check your connection has anyone else experienced this problem?
Forscan said i need an extended license to change the code did you guys have the same problemIm having a hard time connecting to forscan it keep saying ELM not found check your connection has anyone else experienced this problem?
Just get the free 60-day oneForscan said i need an extended license to change the code did you guys have the same problem
Bumping this..when I look at part numbers, it always says antenna, gps, satellite. I want to upgrade, and wonder if I need to change out the antenna to add satellite. Anyone know? From a part listing, I’d guess no, but want to make sure. Thanks!Many have said the 2019 and up already have the GPS antenna, if you add Sirius, is the antenna already equipped for it too?
My 20 did not have the satellite antenna.Bumping this..when I look at part numbers, it always says antenna, gps, satellite. I want to upgrade, and wonder if I need to change out the antenna to add satellite. Anyone know? From a part listing, I’d guess no, but want to make sure. Thanks!
Installed 4" to 8" Screen Upgrade. The stock USB hub in my 2020 base works with the new system. Now I need to get the Drive Mode switch working.
Thanks for all the good info in this thread.
Do it, Its super easy. I think it took me 30 minutes.Shit got to install mine..
Yes auto mode should work. The base climate control is already operated electronically.I assumed as much. How about 'auto' mode. Does that work?
Glad it worked out! What shifter knob is that? Your profile says A10.. that thing looks slick!Installed 4" to 8" Screen Upgrade. The stock USB hub in my 2020 base works with the new system. Now I need to get the Drive Mode switch working.
Not sure, maybe. I don't know if those changes are in the BCM or APIMIce does installing this change any of my other Forscan adjustments, such as EQ bass roll-off.
Yes, A10 White Madness Garage S550 Shifter Conversion Kit with Magnetic BallGlad it worked out! What shifter knob is that? Your profile says A10.. that thing looks slick!
Installed this morning. Parts from a 2019 gt bezel apim and acm that i got off ebay. Plug and play and took about 45 minuets to install and program with forscan. Works great.Thanks for clarifying. Ill post as soon as i get mine installed.
