turnswrench
turnswrench
Parachute installation:
Clamp plate to the mount and measure for center:
Once center, mark your holes:
Drill holes:
Test fit the plate to ensure holes are lining up:
Use plate as template to drill the parachute bag:
Bolt plate through bag to the mount:
Put d-bag in the parachute bag:
Get ready to push the pilot chute in:
Tie up the bag using loop and string, hold loop with parachute release cable:
Pull out bridle strap to appropriate length:
Bolt the bridle strap to mount:
Admire the tag:
Step back and admire the whole setup. Final step is to cut the parachute release cable to appropriate length. Should only come through the loop by about 1". I still need to do that. Don't forget to also pull out the string:
Drill holes:
Admire the tag:
