shogun32
- Feb 8, 2019
- Northern VA
- Matt
- '19 GT/PP, '23 GB Mach1, '12 Audi S5 (v8+6mt)
- Vehicle Showcase
- 2
The IC doesn't help absolute power output per se, it helps *maintain* power during heavy (typically track) use. Mine has a Wagner race unit on it and IAT is consistently 5-8F hotter than ambient. The factory IC is just weak.
Scout the area near both dealerships beforehand and find some good roads if you can. Roads with good corners, sightlines and varied surfaces both good and bad. And drive them in your CX5 so you're familiar with. Also ask the sales guy if he'll let you have the car for an hour or two so you can drive the wife/fam as part of your eval. Unless you come off as a punk kid out for a joy-ride they shouldn't give you any grief over it. You may need to sign a paper regarding damage liability.
As to desired options, the Ford speakers and 'fancy' audio isn't worth a damn if you read the threads here on that. Electronic dash can be retrofitted without too much work but is also not cheap. Ford NAV isn't bad but the voice response is hit or miss. Android Auto and google maps does a much better job anyway.
it definitely is.It was super fast for sure, but the suspension was too stiff.
