-Armoured-
Australia
Wolfgang
Mazda RX7
Amazing build. Looks fantastic (exept for the ricer headlights - so sorry for being a blunt dickhead)
4sdvenom
Fort Wayne, IN
Ken
2003 Mustang Cobra
I think I'm the first to do this swap on a 18+ mustang GT from what everyone has been telling me so after a lot of messages on here and my IG I figured id do a official info and parts list post for people who are wanting to try and do this swap. Just a FYI this swap is EXPENSIVE!! I'm into mine prob $3-3500 with my access to a take off bumper and my Ford pricing I get from local and online dealers deal with. If you bought every single piece new you going to be in the $4500-$5000 dollar range for the swap after you include paint, body work etc. It is A LOT for essentially a front bumper cover swap. That being said its huge upgrade looks wise on 18+ Mustang and for me fixed the non aggressive front end look on these year cars. Aero benefits are also a huge upgrade.
My journey on this swap started with access to a Brand new take off bumper from Ford that was complete but had some minor paint damage and some scuffs on the upper splitter. Mine was complete with all the grills, weatherstripping, side vents, blinkers, wiring harnesses etc. So that saved me a lot of money and time not having to track down and pay for all those parts. Still a lot was needed to make the swap complete. Even though I didn't have to find these parts numbers for what I had gotten Ive found almost all the parts numbers needed and will list those below.
So lets jump into what works with you 18+ car and what has to be changed. Fenders on the Mach are exactly the same as any 18+ trim car besides one thing, holes for badging. Mach have basically EcoBoost fender with no holes for badging since the Mach fender emblems stick on. So any fender will work for this front end swap. The thing that will need to be changed is the inner fender liners. They are Mach specific and tie into the front bumper cover and the underbelly just like the PP1 car do just little bit more extensively. The fender flares on the Mach will also work on any fender as long as you have the Mach 1 bumper. I actually have aluminum GT350 fenders on my car and the fender flares work and fit perfectly on there. I get this question a lot the Flares will NOT work on a regular mustang bumper. The way it Mounts towards the front is specific to the mach front bumper cover. Next is wiring, the 18+ GT's have a different wiring harness for the blinkers, DRL and fog lights. Since the Mach does not have built in fog lights the wiring harness is way simpler and a different plug setup. So there is going to have to be some modifications needed to make the wiring work. I just cut my ends off both the factory harness and the mach blinker harness and built my own connectors using Deutche waterproof connectors. I will post diagrams and pics below of the wiring. The Mach front blinkers are actually the exact part numbers as 15-20 GT350 front blinkers. They look different because the Mach has a trim that shrouds them a little but they are the same. Besides those small things the rest is pretty straight forward if you have the all the parts to do it.
Ok so part numbers, here we go. This is everything I have ordered for mine personally and also some research to find part numbers on what I already had.
Front bumper cover: MR3Z-17D957-BDPTM
Mach 1 Upper Grill: MR3Z-8200-AA
Mach 1 Lower Grill: MR3Z-17K945-AA
Mach 1 Upper splitter: MR3Z-17D957-AA
Mach 1 Left inner fender: MR3Z-16102-A
Mach 1 Right inner fender: MR3Z-16103-A
Mach 1 Underbelly: MR3Z-17626-A
Upper bumper weatherstripping: JR3Z-16A238-B
Mach 1 bumper crash isolator : JR3Z-17C882-B
Mach 1 LH turn signal: MR3Z-13201-A
Mach 1 RH turn signal: MR3Z-13200-A
Mach 1 LH turn signal housing: MR3Z-15266-B
Mach 1 RH turn signal housing: MR3Z-15266-A
Blue push in nuts to go into subframe for underbelly (x6) : W716529S900
Handling Pack part numbers:
HP Lower Splitter: MR3Z-17626-AA
HP Fender Flares: VMR3Z-16268-A
* I cannot find the side vent part numbers or the brake ducting vents from the bumper to inner fenders
**option for turn signals instead of OEM** Diode Dynamics LED turn signals
***push in clips can all be pretty much reused off your old inner fender liners and the hardware off your PP1 underbelly will work for the M1 underbelly. Lower handling pack splitter will come with additional hardware needed to mount to underbelly.
This is everything I can find online from All data, repairlink ford parts list and reaching out to a few dealers to help me. Schematics for the mach parts list are still not out so not everything is available to find. The hardest parts to find are the magnetic colored side vents for the bumper and the brake ducting vents (similar to the GT350). If you have a Whipple on your car you will not be able to to run the brake ducting anyway due to the heat exchanger tank and pump in the drivers side inner fender area. Also the Mach 1 bumper WILL work with ACC(adaptive cruise) cars as long as you don't use the brake ducting vents or if you do want to use the ducting you will have to move the ACC module over more towards the center and recalibrate it in forscan.
My IG is @djericforbes I posted a bunch on there of the swap and my highlights. check that out for more info.
Heres what the inner fenders look like. Besides the brake ducting they have very nice venting from the side vents into the wheel wheel to help cooling:
Stock PP1 underbelly:
Mach 1 underbelly:
My new take off Mach 1 front cover I got:
My swap done:
Wiring!
Heres the 18+ GT premium wiring schematic for the blinkers/fog lights etc:
Blinker wiring for the Mach is pretty much the same as a 15-17 car. Here's a schematic of that:
I will post more info on here as I remember more but for now this is all the time I have and all that I can remember off the top of my head. Like I mentioned above check out my IG @djericforbes bc I posted a lot on there of the swap on my highlights. Thanks!
****EDIT**** See post #46 for instructions to do rear Mach 1/GT500 rear valance swap!
Are those the I-5 Autohaus or MP Concepts GT350 style fenders?
I didn’t see the manufacturer named on your list.
Car looks fantastic.
Ken
V8der
V8der
Las Vegas
Eric
2018 F150 Lariat 502A SCrew 2018 Mustang GT Premium 401A PP A10
Thanks I guess. Lol Little backhanded compliment. A LED technology headlight instead of a HID is Definitely not a ricer headlight but ok. Now if it was some colored halo eyes bullshit I had on there maybe but this is far from it 🤙🏻
V8der
V8der
Las Vegas
Eric
Ken
Their i5 autohaus ones 👍🏼both are made by the same company I believe and just have there brand put on it. Quality is good. I had my body shop crisp up the lines and epoxy primer them then shoot them. Came out good for sure
Orange devil
Ruination
Camaro,toyoda
Thanks I guess. Lol Little backhanded compliment. LED technology headlight instead of a HID is Definitely not a ricer headlight but ok. If it was some colored halo eyes bullshit I had on there maybe.
Your amazing car is not a bottle of tequila..... can't please and fix everyone's problems.
Blu_stallion
Cypress, TX
Don
2020 Mustang GT PP1, 2018 F150 FX4
Absolutely love the outcome, the car looks badass. Great insight on the install details also. I would much rather do a Mach 1 bumper than the GT500 bumpers so many people are doing to the 5.0's. Just seems like a more natural fit for a Coyote-based car. With that said, I'll probably wait until i5auto or one of the other aftermarket companies comes out with an affordable Mach 1 bumper kit. Anyway, great work man, I'll be keeping an eye out for more pics on IG.
Kidd
Kentucky
Sam
2020 GT/PP1 Rapid Red
Swap looks amazing Dude! I didn’t know you were on here, I follow you on IG and was just about to send you a message about all that went into this swap👍
Been looking into this for a while but had sticker shock at the prices lol, glad to see someone like you (who pays attention to detail) do it and do a write up on it.
Anyone hating on bumper conversions or parts swaps obviously don’t remember how popular it was to swap terminator bumpers and hoods on the new edge cars. It’s not “up badging” or “trying to make it something it’s not”, it’s simply an aesthetic/functionality upgrade. As long as someone isn’t throwing shelby or Mach 1 badges on a lower model and trying to convince people that’s what it is then it’s not a big deal
SROhlms
Missouri
Scott
2020 GT Premium
I've never understood why body parts upgrades have become such a big deal on these cars. It has always been really popular to do and was typically viewed as just fine as long as someone wasn't replicating the whole model and throwing badges on it. As you mentioned on the 99-04s, how many people put the Cobra bumper, hood, rear diffuser, side skirts, etc on their cars? Hell, Ford does it plenty on their own now. The GT500 "swing" spoiler started on the GT350 first and made its way onto the Mach 1. Ford reuses wheels, grilles, spoilers, etc all the time.
Just as Eric did here, there's nothing wrong with bringing all of your favorite body parts together on the same car.
Kidd
Kentucky
Sam
Exactly
V8der
V8der
Las Vegas
Eric
Thank you!
V8der
V8der
Las Vegas
Eric
Thanks for following dude! I appreciate it! And I agree 100 percent! 🤘🏽
IPOGT
2021 Mustang Mach 1 Velocity Blue M6
I don't think there are many 2nd generation Firebirds around anymore that doesn't have a Trans Am hood, fenders or both. It's been popular for years.
Advertisement
16 - CJ Pony Parts - 2
Advertisement
