DickR
I owned and autocrossed a 2015 GT PP for 3 years and 31K miles. Oem gear oil. Shifted UP from 1st to 2nd MANY times at over 6500 rpm as fast as I could move the shift lever and the clutch. The only time there was a grinding noise (I know what gear grinding sounds like from over 50 years of driving manual transmissions) was when I either didn't depress the clutch fully, started to lift my clutch foot before moving the shifter all the way into 2nd, or didn't actually move the shifter far enough to engage 2nd before letting the clutch out.These service techs are now telling me the noises are normal. Their reason: Another Mustang GT on the lot makes the same sounds.
I'll record the sound either this afternoon or tomorrow morning and upload it.
With high rpm down shifts keep in mind that these are relatively heavy gears with a lot of inertia. The syncros have a lot of work to do to accelerate the lower gear via friction when you down shift at high rpm without "double clutching". This can make a noise which might sound similar to grinding.
I owned a Lotus Europa decades ago that fast 1 - 2 shifts over 7000 rpm with tired syncros would result in gear grinding simply because the whimpy syncros in those days couldn't keep up. This was called "beating the syncros" back in the day.
