PTM5.0
- Nov 26, 2017
- MO, IL, and KY
- '18 GT PP A10
How many others are still waiting months later also?
Nobody should, were shipping at a pretty high rate right now and fulling new orders in normal time frames.How many others are still waiting months later also?
Over 3 months and no kit has arrived at the performance shop. Supposedly shipped last week but no tracking number. I was given 4-6 weeks when it was ordered....Nobody should, were shipping at a pretty high rate right now and fulling new orders in normal time frames.
I just got back from vacation and picked up my car with the whipple installed . Feels like Christmas in August. lolWith the DW pump and some id1000, if you add a bap, you can run 3.625” on e85, without a return style fuel system. This will make a ton of power.
Question is will any of the “big 3” tuners tune it with just a BAP?With the DW pump and some id1000, if you add a bap, you can run 3.625” on e85, without a return style fuel system. This will make a ton of power.
Here's a sample guide.
PULLEY/BOOST/132MM TB
SC Pulley/Boost/stock balancer
4.000" 9.5
3.875" 10.5
3.750" 11.5
3.625" 12.5
3.500" 13.5
3.375" 14.5
3.250" 15.5
3.125" 16.5
3.000" 17.5
2.875" 18.5
2.750" 19.5
20% OD is worth just over 5psi.
Long tubes with cats drops boost .5-1.0psi.
Long tubes with no cats drops boost 1.0-1.5psi.
Many other factors can vary boost +/- 1psi.
Which BOOSTane ?Unleaded fuel is best for O2 and cat life. I ran Octanium before, it works but its hard on O2 sensors. I tried Boostane and I honestly run it in every car I own. It's incredible. So far, spark plugs, o2 sensors, all good. Many of my employees run it when they go to the track, it really helps us pump gas guys. 93 is so much better than 91 octane, we find it to be a net difference of 4deg of timing in general. If you run 1/2 a can of Professional boostane per full tank, a 91 octane customer will hold 2-4 deg's more timing at WOT nearly every run. We don't have nearly as much experience with it on 93, but on 91, its big for the simplicity of it.
The professional boostane as he mentioned above. 1/2 can per full tank. I use it. Works well, my car gives max timing.Which BOOSTane ?
Premium that raises octane up to 100 .website says for lower compression
https://boostane.com/product/boostane-premium-octane-booster-1-quart/
Or
Professional?
https://boostane.com/octane-boosters/boostane-professional-octane-boosters/
Website says for higher compression engines and raises octane up to 116.
I like the sound of the later so going to order a case .
