djodadof2
Hi, All. First post here.
I've searched for an answer and can't find one, so any help is appreciated.
I just got a 2018 GT Premium PP1 and after a few days the steering wheel developed a large amount of play, as if the mounting bolt was loose. I presume that the seller had upgraded to another wheel and returned the old one before selling the car, and did a bad job of attaching it. Regardless I proceeded to remove the airbag to get at said bolt. One side was easy, the other side not so much. After groping blindly in the hole with a screw driver for 1/2 an hour I finally manged to find the retention spring and push it to get the airbag off. Sure enough the bolt was not even finger tight.
However... in the process of fighting to find the second spring I managed to damage some of the wires in the wiring harness inside the wheel. The harness was just past the spring, and without knowing it I was missing the spring with the screw driver and pushed into the wires which severed a few of them. This harness carries the wires that connect the steering wheel controls (e.g. audio, cruise, etc.) to the main interior harness.
My dealerships and all my searches suggest that the only way this harness is available is by getting the entire main dash harness, which is almost $600 and out of stock. The exact harness depends on the car's features because they don't just include all the leads in the harness even if the car doesn't have the features; instead there is a different wiring harness for each configuration.
My question is: can this harness be obtained on its own by some means?
