2018 GT MT82 1-2 shift impossible at high RPM
Discussion in 'Mustang S550 General Forums' started by Shdwblk_18s550GT, May 18, 2019.
  1. Shdwblk_18s550GT
    First Name:
    Adrian
    Vehicle(s):
    Feb 5, 2019
    Ontario, California
    I put in a Barton Hybrid 3, still cant do a 1-2 shift at high RPM.... and now I installed a trans mount void insert from Whiteline.....still cant 1-2 shift at high RPM, oh and now the car vibrates like a motherfucker. I JUST WANT TO BE ABLE TO DO A 1-2 SHIFT LIKE EVERYONE ELSE.......WTF!!!????
  2. rebellovw
    rebellovw Well-Known Member
    Vehicle(s):
    2018 Mustang GT Premium PP
    May 23, 2018
    481
    320
    0   0   0
    Hhaaaaaahhhaaaa
  3. NoVaGT
    NoVaGT Well-Known Member
    Vehicle(s):
    2019 PP1 GT Kona
    Sep 29, 2016
    Northern Virginia
    3,715
    2,303
    Rating:
    100%
    1   0   0
    Take it to the dealership.
    After you return it to stock.
  4. IronG
    IronG Well-Known Member
    Vehicle(s):
    2019 Mustang GT PP2
    Aug 6, 2018
    1,081
    458
    0   0   0
    What do you consider high RPM? I can shift no problem at 7k. As Nova said, take it to the dealer once you take off the mods.
  5. BmacIL
    BmacIL Enginerd
    Vehicle(s):
    2015 Guard GT Base, M/T
    Sep 21, 2014
    Naperville, IL
    14,456
    8,348
    Garage Profiles:
    Rating:
    100%
    3   0   0
    Get rid of that trans mount insert and transmission mount the shifter. Add BG Syncroshift II fluid.
  6. revinto7
    revinto7 Well-Known Member
    Vehicle(s):
    07 shelby-gt 14 camaro SS 1LE
    Jan 4, 2015
    NY
    346
    105
    0   0   0
    do what i did .when you want a smooth shifting transmission as high as 8500 rpm without a hiccup ..Swap to a T56-Magnum XL 2.97 1st gear .Best transmission i ever owned !! Internal rail shifter with no External linkage and it doesn't change geometry when under load ..no vibrations and actually almost impossible to ever miss a gear even third .
  7. Ebm
    Ebm Well-Known Member
    First Name:
    Guy
    Vehicle(s):
    '14 GT
    Nov 21, 2016
    North Carolina
    2,653
    926
    0   0   0
    It's a protection feature hehe.
    All kidding aside, try a different fluid than the factory fill to see if that cures your issue. If not, you need a harder material trans mount(and might as well get upgraded motor mounts too) to keep everything in place. The stock mounts are meant to keep NVH down. They are just too soft though.
  8. SVTSNAKE355
    SVTSNAKE355 Banned
    First Name:
    hothands
    Vehicle(s):
    2014 GT500
    Aug 22, 2018
    chicago
    434
    244
    0   0   0
    MGW SHIFTER
  9. gixxersixxerman
    gixxersixxerman Well-Known Member
    First Name:
    Thomas
    Vehicle(s):
    2018 GT Premium PP1
    Jul 3, 2017
    Las Vegas
    594
    264
    Rating:
    100%
    1   0   0
    Same, I’ve lived with it for over a year. Ford said shifting over 7k was not normal operating range, only “racing”. Fact is replacing the clutch that’s suppose to fix it with another stock may/may not help. MGW did nothing, new amsoil cocktail did nothing. The Steeda clutch line helped a lot but still not as fast as it should be. I’ve been in 2 other GT’s and no problem. Can shift as fast as I want. No lift it’s fine. Mine couldn’t shift over 6300 any where near quick or it would grind or stay locked out.
    Honestly I’m waiting for the shift fork to go then doing a mantic. Clutch is “suppose to fix” it. But hard to throw 2k+ down on a maybe
  10. VelocityB
    VelocityB Member
    First Name:
    Bryan
    Vehicle(s):
    2019 Premium GT
    May 20, 2019
    Ohio
    I had the same issue so I traded the 18 in on a premium velocity blue 19 with auto. Shifting is awesome in a manual but that mt82 needs help.
  11. revinto7
    Vehicle(s):
    Jan 4, 2015
    NY
    346
    105
    0   0   0
    the mantic will work because its a smaller diameter which equals less centrifugal force and will disengage and release much faster and more thoroughly which will stop the grind .i used a mantic 9000 in my 2014 1000 hp 1LE build it was a great clutch
  12. OP
    Shdwblk_18s550GT
    First Name:
    Adrian
    Vehicle(s):
    Feb 5, 2019
    Ontario, California
    Ok so after a few tantrums, I decided to go body mounted with the Barton instead of trans mounted and that seems to be the solution. Still getting used to the shorter throw but I can row thru gears like a boss now no matter how high the rpm.I dont even mind the vibration as it is minimal....I was just being an exaggerating lil girl cuz I was mad........its all good now.
    stanglitt and Mustang Tony like this.
  13. NoVaGT
    Vehicle(s):
    2019 PP1 GT Kona
    Sep 29, 2016
    Northern Virginia
    3,715
    2,303
    Rating:
    100%
    1   0   0
    I like your honesty. It's refreshing.
    Glad you got it figured out.
  14. Wile-E Coyote
    Wile-E Coyote Active Member
    First Name:
    Vehicle(s):
    2015 race red GT PP
    Sep 10, 2018
    Canada
    38
    i had the same problem, i installed a steeda race shifter and it went away. On the bartons there is some adjustment on the main block of the shifter, you may need to shift yours to the side to "tune" the shifter.
  15. FreedomPenguin
    FreedomPenguin Well-Known Member
    First Name:
    Donald
    Vehicle(s):
    2017 Mustang Ecoboost Premium, 2013 Scion tC.
    Aug 20, 2018
    Dayton, Ohio
    620
    231
    Occupation:
    Gov
    Rating:
    100%
    1   0   0
    I have the hybrid Barton 3 body mounted as well (ecoboost premium) I love the feel, no issues w shifting. Throwing into reverse is a little tougher than stock, safety feature though. Used to be butter
    Now it’s butter but the butter is cold instead melted lol. Gotta give it a nice push over for it to pass the reverse jump. Smooth none the less
Loading...
Share This Page
