saleen367
OK, I'm throwing this out there to see if anyone has ever come across anything like this before.
2-3 weeks ago, I wash the car and back it into the garage and towel dry it out of the sun. Thought nothing of it, until I went to drive it about a week later. Fire it up, put the car in gear (M-82) and nothing ... try and again and it won't budge. Finally on my 3 attempt, the wheels break loose of the pads and I'm on my way, but I remember thinking how very strange that was. Reminded me of having frozen brakes in extreme cold.
August 30th, I do the same thing ... wash, back into the garage and towel dry. Left it sit till last night. Wanted to go out for a quick drive after taking in some football. Once again, fire it up, select 1st gear and no go. This time it was so bad, it would bog the engine and would have killed it even with giving it some RPM's. Finally after several tries I broke it loose and came to a stop in the driveway, only to hear this god awful noise from the drivers side brake.
Got out, checked the rotor, nothing noticeable. I pull out into the street, all is good. Hit the brakes at next intersection and once again this pounding noise from the front brake. I gingerly got the car back home and parked it back in the garage trying not to use the brakes.
Here's what I found after further inspection ... the brake pad seems to be rusting/adhering itself to the rotor so bad that a small piece of the brake pad is still stuck to the rotor ... check out the pics. The left rotor still has some surface rust from sitting (top pic), so I know something is not working properly with the caliper.
I'm taking it in Thursday, but the service advisor thought I was nuts when I told him what was going on.
Anyone ever seen this before?
