DTeal23
Post #3“Same fuel as previous 805 pull, 863hp 677tq (still only seeing 20*)“
On 10 psi?
On 10 psi?
Must be engine numbersPost #3
What's happening is the elevation in Denver is depriving the car of making a ton of boost (3.5 pulley should be around 15 psi normally), but here it only made around 10 psi.Must be engine numbers
With the Dyno's correction factor coming into play, the power seems like a lot for not that much boost, but it's probably pretty accurate. In other words, the uncorrected dyno number is probably much lower and close to what the car would actually make on 10 psi, but the correction results in the higher number shown.
850+ on a Whippled Gen 3 car with high octane fuel seems pretty accurate to me. If he were to bring that same setup to a place with 0 DA, he'll make a ton more boost and the dyno will probably read something similar still.
At least that's what I think is happening here lol
Without posting the correction coefficient? Yes.So why post the corrected number is it’s meaningless?
643 is probably pretty accurate if the car is mostly stock on the whipple tune and injectors. Most go away from whipples canned tune because a 3rd party tune doesn't have to meet any federal guide lines. They tend to get more power and run smoother as they are more specific to your set up. Once you can upgrade injectors and get a custom tune it becomes much easier to break into 700+ hpSo, forgive me a bit but I am rather new to the FI world and the S550 platform.
I have a 2018 with a Whipple 3.0 / Stage 2 so I believe that is the larger throttle body and 3.875 pulley.
I just cruise, so I run 93 octane, stock Whipple everything.
Why are some ignoring the out of the box, Whipple tune and going wild with other tuners? Is it because you are running smaller pulleys and Whipple won't support that, is it pure user preference, ...?
I am in New England (so, not crazy elevation here). Can you give me an idea what the 'out of the box, Whipple Gen 3' is running for boost and hp/tq numbers? I have not had the car dyno'd. The previous owner did the work, it all checks out with a reputable shop and documentation. He showed me a dyno sheet where this car is putting 643whp; seems a tad low compared to some others.
Thank you, love to learn this all!
interesting. So, people go third party because it’ll run ‘smoother’ ?643 is probably pretty accurate if the car is mostly stock on the whipple tune and injectors. Most go away from whipples canned tune because a 3rd party tune doesn't have to meet any federal guide lines. They tend to get more power and run smoother as they are more specific to your set up. Once you can upgrade injectors and get a custom tune it becomes much easier to break into 700+ hp
I have the Whipple tune primarily due to emissions requirements. If you are looking to get every possible HP then going with a different tune/setup is going to get you closer to that goal.interesting. So, people go third party because it’ll run ‘smoother’ ?
hmmm... I guess my set up or plan rather is to just keep it steerable and keep it easy to RIP ;). Is the Whipple time ‘fine’, specifically for long term power and reliability.
When adding that much more power (injectors and tune tweaking), would likely cause more concern with our transmissions correct? (I have a 6 speed)
