2018 BULLIT OR GT350 CAI
Notagain
United States
yellow 2016 5.0 totaled white 2018 A10 now
Has anyone used a GT350 or Bullitt on a 2018? Id assume either will work but want to verify the TB is the same size on the 18 GT, GT350s and Bullitt?
Looking to keep factory fit and finish but Id like one that seals against the hood when closed too.
I dont get why this isnt a more popular option since 1. PMAS fit and finish is garbage. 2. The Steeda one doesnt work well on E85.
The JLT one seems to be best other option IMO.
Brazos609
2015 GT Premium PP Recaro
I haven't heard of anyone even trying to order or gathering the part numbers for the Bullitt intake manifold, throttle body, intake tube, and airbox.
Zelek
Round Rock / Hutto, TX
2021 Mustang Mach 1
The Steeda one does work on an E85 straight tune or 93 tune. Just no flex tunes. They are revising it to have a version that will work with all tunes. That one will be worth waiting on. Stick with the stock intake for now if you have that, imo.
Notagain
United States
Ford sells the FRPP stage 3 kit with GT350 Manifold TB and CAI pmus tune. But wouldnt need the tune.
I dont think the GT350 intake would be worth buying over the stock 18 intake manifold.
If I was changing manifolds Id go straight to CJ
Only reason I brought up the GT350 cold air intake is it would be nice to use on an 18 for its fit finish and seals against the top of the hood.
Brazos609
There are no FRPP kits for 18+ and the Bullitt does not just use GT350 parts. The Bullitt airbox is the only one that actually seals against the hood properly and is completely different from the GT350 airbox.
EVL-S550
Northern VA
I looked into it. Had all the part numbers gathered and it's not worth it vs getting the Roush CAI or staying stock with a drop in. The TB is different on the Bullitt and GT350 - 87mm vs our stock 80mm. The Bullitt air box fits the 18+ hood line, while the GT350 is a bit off and doesn't seal properly on the 18+. Lastly the Bullitt has the same MAF while the GT350 has a different MAF. The real difference between the Bullitt and the 18+ GT cars is the tune. Load a tune in from a reputable tuner with a filter upgrade on the stock box or buy a Roush and you'll be the same as the Bullitt or likely faster.
