knightvision
- Sep 28, 2015
- West Virginia
- Alvin
- 2016 Ford Mustang GT "Triple Yellow"
Today
I started today with the G-Trac Brace install. Overall, very easy but I ran into a simple issue. I had difficulty trying to balance the spacers on the bolts up front and then holding it up while starting the nuts. Two hands would of made this super simple. I thought I was done and found that one spacer had slipped off, which required me to drop the entire thing to put the spacer back on. Aside from that it was a straight forward install. I also added a set of washers on the underside of the rear bolts as I thought the bolt head didn't grab enough material and the ob-longed hole it went into... just added insurance for me.
That reminds me I still gotta cut the wire off the front spacers...:doh:
I also got the last bushing support spacer in.So these two parts from the "Stop the Hop" kit are done.
555-4437 - 2015 Steeda Mustang IRS Subframe Bushing Support System
555-4438 - 2015 Steeda Mustang IRS Subframe Alignment Kit
And for those you following a sneak peak at the tires...
Nitto 555 G2 275/35/20
Nitto NT05R 315/35/20
