Arizona 2016 HPDE Mustang GT Partout (BMR/Steeda/FRPP/Schroth/FTBR/etc...)
AlbertD
Tucson, AZ
2016 GT/PP
Everything is in good working condition, recently removed from my 2016 Mustang GT PP that was primarily used for HPDE.
Prices do not include shipping, if you would like a shipped quote post or pm me your zip. Shipped items will go out via Fedex w/tracking info provided.
Located in Tucson, AZ.
If you have any questions, feel free to ask!
$125 BMR rear shock mounts w/BMR rear brace p/n: SM760/STB762
Note: The smaller support bolts had stripped out so I drilled out the mounts and bought equivalent grade allen bolts. They pass through the mount and use a separate nut. Including the allen key for convenience.​
$35 BMR rear camber lockout p/n: WAK761
$65 GT350R rear sway bar p/n: FR3Z-5A772-E
$65 Modified OEM differential cover p/n: GR3Z4033A
Note: Diff cover has been tapped for an additional fill port (1/2 NPT) and also tapped for an additional oil temp sensor (1/8 NPT). I am including a plug for the fill port, but not for the temp sensor. The diff mounting holes have also been drilled out for a "through bolt" setup. This will not work with the factory diff mounting hardware. I specifically used the BMR poly bushing hardware.​
SOLD Steeda front control arm lateral links w/ extended ball joint p/n: 555-4906
SOLD Schroth SHR Flex HANS, medium w/pads p/n: 42602
SOLD Full Tilt Boogie Racing shifter reinforcement bracket p/n: FT 590
SOLD GT350R front sway bar p/n: FR3Z-5482-J
SOLD BMR rear adjustable toe rods p/n: TR005
SOLD BMR poly vertical links p/n: TCA048
SOLD Steeda rear adjustable camber arms p/n: 555-4123
SOLD Schroth quick fit pro, driver side p/n: SR 19610
SOLD Damper package, incl:
FRPP track dampers p/n: M-18000-F with
BMR handling springs p/n: SP084RC/SP085RB with
Steeda camber plates p/n: 555-8139
SOLD K&N air filter w/recharge kit p/n: 33-5029
SOLD Mishimoto air intake tube p/n: MMHOSE-MUS8-15IHRD
SOLD Ford PP front radius arm with BMR spherical bearings p/n : CBK760
SOLD Rear subframe (manual trans) w/ BMR poly diff and BMR solid cradle bushings p/n: BK049/BK048
AlbertD
AlbertD
Tucson, AZ
2016 GT/PP
Bump
AlbertD
AlbertD
Tucson, AZ
2016 GT/PP
Prices reduced...
AlbertD
AlbertD
Tucson, AZ
2016 GT/PP
Bump for another price drop. Willing to separate the dampers and also willing to sell the rear subframe bare if you want to use your own bushings. PM for pricing.
CompOrangeGT
Enterprise, AL
2015 Mustang GT
Pm'd
