AlbertD
- Jun 18, 2016
- Tucson, AZ
- 2016 GT/PP
2016 Ford Mustang GT Base with Performance Pack
~64,050 miles, One owner, non-smoker, clean title in hand, 2 key fobs included
VIN: 1FA6P8CFXG5226165
$29,500 OBO
With life priorities and baby #2 on the way I have decided to get a 4 door vehicle, so unfortunately I have to let my beloved mustang go. I wish I had room for it.
This car is mechanically in perfect condition and never fails to put a smile on my face everytime I drive it. Shifts are crisp, the exhaust sounds amazing with the valves open (quiet with them closed) and the motor pulls just as hard and runs as smoothly as it did when I bought it new 6 years ago. This car has seen HPDE track time so it has a fair amount of rock chips, however it still shines up nicely and continues to turn heads everywhere I drive it.
All maintenance and custom modifications were fabricated by myself. I have an automotive technician education background, ~15 years of racing experience and am an engineer by trade so I put a lot of design/effort/care into how these custom systems are made and installed. Everything on the car is "functional", tested and of high quality.
I have removed all racing suspension from the car and re-installed most of the stock PP suspension. The suspension is either brand new or low mileage from a PP mustang. It literally drives like a brand new car off the lot. I decided to leave a lot of the custom modifications that really make this an outstanding and reliable track car. You can drive this car to the grocery store in style/comfort and at the same time, if you wanted to see what it can do on the race track... it will take everything you can throw at it. The cooling and aero modifications I have made are all purpose built and track tested over the past few years.
In preperation for sale, I gave the car a fresh alignment, replaced all fluids, put on brand NEW OEM wheels/tires/tpms, replaced the windshield and put on a fresh set of low dust street brake pads.
I will list all mods currently on the car and other items that will be included with the sale. I am more than happy to explain the car in detail, so please feel free to ask questions. I am completely transparent with the car and want the new owner to be happy with it!
Engine
- Custom oil catch can system for Driver and Passenger side, built in drain valves for maintenance.
- Sound tube delete
- Aluminum coolant reservoir
- Moroso 10qt road race oil pan with internal baffling
- GT350 driver side valve cover (corrects issue with PCV system during high lateral right hand G forces)
- Honeycomb radiator protector
- Steeda H mid pipe
- 2018 OEM exhaust with valves. Custom setup to open/close the valves with a switch mounted behind steering wheel.
Transmission
- Exedy lightweight steel flywheel
- Exedy Mach 500 organic clutch
- Exedy throwout bearing
- FRPP shift knob
Cooling
- Front grille airflow increased
- Custom radiator enclosure
- Custom hood and fender vents. Hood has custom aluminum rain tray (removable). Zero issues out in the rain/downpours.
- Steeda front splitter with custom brake air ducts
- Vorshlag brake deflectors
- Custom FRPP transmission cooling scoop
- Back end of exhaust wrappped with thermal wrap
- Custom differential cooling system... pump, radiator w/fan, AN lines/fittings, service switch under car (for drain/fill) and switches on center console (one for fan and the other for pump)
- Engine, transmission, and differential oil temp sensors with triple A pillar gauge pod (switch on pillar to turn off gauge lights)
Aero (downforce)
- Custom hood/fender vents (also listed under cooling); validated via tuft testing and track performance
- Steeda front splitter (also listed under cooling)
- OEM GT500 rear swing with track gurney flap installed
Safety
- ZL1 addons front tow hook (removable)
- Aerocatch hood pins
- Schroth quick fit pro harness (removable)
- Schroth HANS flex
- BELL helmet
- Element Fire extinguisher intalled in glove box
Suspension/other
- Strut tower holes increased to allow more camber adjustment
- FRPP rear toe bearings
- Steeda RLCA bearing
- Lethal performance hardware/centering sleeve upgrade for rear diff mounts
- Steeda heel/toe pedals
- Roush rear valence
- Quicklatch pins for front bumper
Maitenance:
- Engine: Motorcraft 5w-30 Full Synthetic and OEM filter every 3k miles or 3 track days. K&N air filter cleaned every 6 months. Spark plugs replaced annually. Oil samples from Blackstone labs show engine has better than average wear characteristics.
- Transmission: BG Syncro Shift II every 6 months
- Differential: Motorcraft Rear Axle Oil 75W-85 w/friction modifier every 6 months
- Brakes: Castrol SRF Fluid full flush and brake pads done annually.
- AC system replaced with brand new OEM components at 60K miles: New compressor, condensor, and expansion valve.
- Rear camera wiring harness extended (Ford TSB)
Flaws (Mainly cosmetic - see photos as well):
- Rock chips/paint imperfections from track driving
- Passenger headlight has one DRL strip that doesn't turn on, the other two DRLs work
- Passenger side corner/lip of the hood has a small dent
- Front bumper PP splitter had cracked and was repaired
- Trunk button by license plate does not work. Key fob trunk and in-car trunk buttons both work.
- Windshield wiper had some paint scraped off at base (it had loosened at some point and rubbed)
Videos:
Exhaust closed (startup/rev) vs open (revs)
Exterior walkaround
Interior walkaround
$29,500 OBO
Engine
- Sound tube delete
- Steeda H mid pipe
Transmission
- FRPP shift knob
Cooling
Aero (downforce)
Safety
- Schroth HANS flex
- BELL helmet
Suspension/other
Maitenance:
Videos:
Exterior walkaround
Interior walkaround
