XP Motorsports
- Jan 27, 2020
- Longwood Florida
- Website
- www.xpmotorsports.com
- sales
- ford
(F) 6-Piston Cast Monobloc Calipers | 405x34mm (15.9'') 2-Piece Discs | Complete Axle Set | Pre-Assembled | All Necessary Hardware Included
Cast Monobloc Radial Mount 6 Piston Inner Pressure Seal / OEM Approved Dust Boot
Disc Type:
Cross Drilled
Slotted
Type 3
Disc Material/Finish: Advanced High Carbon Alloy / Corrosion Resistant Plating
Disc Diameter: 405mm or 380mm
Disc Width (Measurement): 34mm
Disc Air Gap (Measurement): 12mm
Disc Annulus (Measurement): 62mm
Disc Construction: 2-Piece Disc Assembly
Disc Vane Design (Measurement): Vented Curved 48 Vane
Disc To Hat Mounting System: Floating H-Bobbin with Anti Rattle Spring
https://www.xplosiveperformance.com/2016+FORDMUSTANGGT405mmor380mmRotorFrontSystem
$4995.00
All Brembo Kits for Mustangs 6th Gen
https://www.xplosiveperformance.com/Big-Brake-Kits_c_13535.html
Disc Type:
Cross Drilled
Slotted
Type 3
$4995.00
