wildcatgoal
@sirboom_photography
I put split loom over the wiring to my trunk door because mine would get caught in the seal. Ford really f'd up that wiring, IMO. Really quite the amateur hour back there.
I am sorry but I have a nonconvertible. Have you tried using the key with the top down and up? It must be frustrating not being able to use your trunk. Wish I could help.That’s exactly what I did but the trunk didn’t budge. Does it take a lot of pressure when turning the tiny key?
I took mine out of warranty to the local Dealer. The local dealer wanted $150.00 Just to look at it. This cost would not be rolled into the cost of the repair. At least that is what the service rep told me. That is when I decided to order the latch. It only cost me $75.00 ordered on line. But as you know that was not the problem. The issue is in the wire-harness. Maybe your dealer will help you out since its just out of warranty. Good luck yo!Damn, looks like I'll be taking this to the dealer and I'm only a few months out of bumper to bumper warranty.
Anyone go to the dealer for this out of warranty? If so how much did it cost?
Possibly since it is a video single it might require a special thickness and quality. I am not sure. I am a computer tech by trade. Dont know much about AV.. You should try a local Audio Video store and see if they can get you the right wire type.So I found where the camera wire was damaged and I added wire to lengthen it, but doing so it would only turn on intermittently. Once I move the decklid around, the camera would go off and on, off mostly. I even inline spliced it instead of pigtailing, but I did use a slightly larger wire. Could that be the issue?
I am glad they got you fixed bro.I just got my 16 back from having the wiring repaired. My Trunk would open but the camera would wig out intermittently. Luckily I am still under the factory warranty.
Hi, just got the car back. Correct you are the repaired the harness, and assured me it won’t happen again. I told them yep, if I don’t put anything in the truck that will hit the harness that hangs when you close the trunk lid.More than likely they will repair the harness. That is what they did on mine. Mine is still wigging out on occasion. I have got to take it back.
