Sold: Virginia 2015 GT Premium 6MT PP NA with track and street upgrades
tweekdout
Ashburn, VA
2015 GT PP 6m
2015 GT Premium Performance Pack Premium Deep Impact Blue with multiple street & track upgrades. Always garaged, 27k miles driven in GA & VA in summer/fall/spring. Interior and exterior are clean. Interior is black leather AC seats from premium with heat. Subwoofer in the 401A Shaker option. Current MPSS tires and McLeoud dual disk clutch have <3k miles on them, and recent fluids change in winter.
Car has been meticulously taken care of with synthetic oil, Motul RBF 600 yearly, Ford factory recalls completed, and tuned & inspection x2 in VA when moved 2018.
Driveline
  • Steeda Tri-Ax Race Short Throw Shifter
  • Steeda Adjustable Differential Bushing Insert
  • Steeda Heavy Duty Braided Clutch Line
  • Raceseng shift knob ‘Globular’
  • Driveshaft Shop solid aluminum shaft & balance
  • McLeoud street twin disc clutch (less than 2kmiles)
Engine
  • Steeda ProFlow Ultimate Induction Power Pack
  • SCT Tuner + profile for catted headers and cat back with no restrictor
  • Sound restrictor removed and sound tube deleted+plugged
  • Open mesh on driver side hex grille for IAT
  • Kooks Green Catted Headers (passes VA emissions as-is)
  • Magnaflow Street Cat back
Suspension and Brakes
  • Steeda Front and Rear Sway Bar Kit
  • Steeda IRS 'Stop the Hop' Package
  • IRS Subframe Bushing Support System
  • IRS Subframe Alignment Kit
  • Billet Aluminum Vertical Links
  • IRS Subframe Support Braces
  • Adjustable Rear Toe Links
  • Steeda Billet Front and Rear Sway Bar Mount Kit
  • Steeda Bumpsteer Kit
  • Steeda Extreme G-Trac K-Member Brace
  • Steeda Lower Control Arm Bushing
  • Steeda Front Camber Plates
  • Steeda Rear Adjustable Camber Arm
  • Steeda rear heavy-billet shock mounts
  • KW V3 all around
  • Steeda Stainless Steel Brake Lines
  • JLT driving light cooling ducted front brakes (have lights)
  • Brembo street pads
  • MRR FS01 Bronze 19 X 10/11 + Michelin Pilot SS 275/305 (<4k miles)
  • Setup
    • Front camber; -2.4 Toe; 0 Compression; -10 Rebound; -9
    • Rear camber; -1.9 Toe; 0 Compression; -9 Rebound; -7
    • Motul RBF 660 Brake Fluid (flush & fill each season)
Other
  • APR front splitter and canards
  • Steeda functional rear wing
  • Anchor room light tint for headlight side markers and rears
  • UPR black-out badges
  • Diehard AGM Battery 2020
  • 3M 60% window tint sides and back
Have most all original parts in boxes. DO NOT ASK for part outs, as stated is what's included. Have paperwork and dyno sheets from 2019.
Asking $32k or best reasonable offer. Be serious and text me with offer and call back time (I work alot) and I'll get back; 646-321-9749
terion
Ukraine
Volodymyr
GT PP MT 2016 (restyled)
Sorry for off-top, but are you happy with Steeda Tri-Ax Race Short Throw Shifter? Did you compare it with mgw and barton?
tweekdout
tweekdout
Ashburn, VA
2015 GT PP 6m
I did and preferred the Steeda
tweekdout
tweekdout
Ashburn, VA
2015 GT PP 6m
Seems like I try to sell right before Spring then think twice before the season starts. Trying this again - it's up for sale!
shogun32
Northern VA
I've seen and ridden in this car and it's all there. Nice chap, too. :)
tweekdout
tweekdout
Ashburn, VA
2015 GT PP 6m
It's summer and it's back up 🤣
