Advertisement
2015 Ford Mustang STO-N-SHO Removable Front License Plate Bracket Mount
RPI Designs
Gold Sponsor
Posts
880
Salem, Ohio
www.rpidesigns.com
2015 Mustang GT - Test Mule
2015 Ford Mustang STO-N-SHO Removable License Plate Bracket
Big Mike’s Performance Parts’ STO N SHO™ is an aftermarket detachable front license plate mounting system that is designed for those cars whose appearance would be ruined by use of the factory mounting location. Stay in compliance with state law by simply STOing your front license plate when you want to SHO the beauty of your car.
Big Mike’s Performance Parts’ STO N SHO™ is a two-piece detachable mounting system consisting of a front license plate holder and a base mounting plate.
Removal and installation of the front license plate is easy
Requires only the pull of a spring loaded pull pin Remaining base plate is virtually undetectable The STO N SHOTM aftermarket detachable front license plate bracket mounting system is manufactured in the USA using quality materials and parts. The front and base plates are precision laser cut and hand burnished. Each tube and rod is machine cut and hand cleaned. Each STO N SHOTM aftermarket detachable front license plate bracket mounting system is expertly hand welded and drilled. After it’s assembled the base plate welds are ground smooth. The bracket is then anodized black. The final step in the process is to install the pull pin and test the product. While the bracket may look simple in appearance, a lot of time and work goes into making each STO N SHOTM aftermarket detachable front license plate bracket mounting system to ensure you receive a quality product.
Constructed of 5052 and 6061 aluminum Welded and anodized black Built to last and comes with a limited life time warranty Big Mike’s Performance Parts” STO N SHO™ requires small holes to be drilled on the underside of your vehicle. These holes are not visible and in no way detract from the look of your car.
Requires 2 holes All parts required for installation included, however, tools are required.
2015 Ford Mustang STO-N-SHO Removable License Plate Bracket Version in stock here: http://www.rpidesigns.com/shop/item.aspx?itemid=5032
2015 Ford Mustang STO-N-SHO 50th Anniversary Removable License Plate Bracket Version in stock here: http://www.rpidesigns.com/shop/item.aspx?itemid=5033
:thumbsup:
FranzVonHoffer
Posts
918
Houston
Black Mustang Base GT TP
Excellent product but be advised on lowered cars watch pulling up too close to curbs. I've torn one of these off already and Im on my second one. It's not the products fault but people with lowered Mustangs should be careful how you park.
control4userguy
Posts
378
Los Angeles
2018 GT Premium
Any fitment info for 2018 M.Y. GT w/PP?
RPI Designs
Gold Sponsor
Posts
880
Salem, Ohio
www.rpidesigns.com
swooshdave
Posts
266
Portland, OR
2019 Mustang GT Premium
Not yet. Hopefully, the manufacturer will let us know soon about 2018 fitment.
Other suppliers have the 18-19 mount. Are you carrying them yet?
RPI Designs
Gold Sponsor
Posts
880
Salem, Ohio
www.rpidesigns.com
Advertisement
Advertisement
Advertisement
