northamericantuning
Mustang Parts Vendor
- Nov 19, 2014
- Ohio
- Website
- www.northamericantuning.com
- 2015 Mustang GT
2015 Ford Mustang STO-N-SHO 50th Anniversary Removable License Plate Bracket
Big Mike's Performance Parts' STO N SHO for 2015 Ford Mustang 2.3/GT/V6
(only fits 50th Anniversary Edition or 5.0 with Performance Package)
Big Mike’s Performance Parts’ STO N SHO™ is a two-piece detachable mounting system consisting of a front license plate holder and a base mounting plate.
Removal and installation of the front license plate is easy
Requires only the pull of a spring loaded pull pin Remaining base plate is virtually undetectable The STO N SHOTM aftermarket detachable front license plate bracket mounting system is manufactured in the USA using quality materials and parts. The front and base plates are precision laser cut and hand burnished. Each tube and rod is machine cut and hand cleaned. Each STO N SHOTM aftermarket detachable front license plate bracket mounting system is expertly hand welded and drilled. After it’s assembled the base plate welds are ground smooth. The bracket is then anodized black. The final step in the process is to install the pull pin and test the product. While the bracket may look simple in appearance, a lot of time and work goes into making each STO N SHOTM aftermarket detachable front license plate bracket mounting system to ensure you receive a quality product.
Constructed of 5052 and 6061 aluminum Welded and anodized black Built to last and comes with a limited life time warranty Big Mike’s Performance Parts” STO N SHO™ requires small holes to be drilled on the underside of your vehicle. These holes are not visible and in no way detract from the look of your car.
Requires 2 holes All parts required for installation included, however, tools are required.
Available here:
http://www.northamericantuning.com/...HO_50th_Anniversary_Remov_p/15-stosho-anv.htm
Available here:
