2015 Ford Mustang Magnum FLOW OER aFe Air Filters
Discussion in 'V8 Bolt-Ons & Tunes' started by Southern Car Parts, May 19, 2015.
  1. Southern Car Parts
    Southern Car Parts Well-Known Member
    Gold Sponsor
    Vehicle(s):
    2015 6spd GT
    Dec 18, 2014
    Atlanta, GA
    350
    Features:
    • Oil-Free, Pro DRY S 3-Layer Progressive Porosity Synthetic Media for maximum convenience
    • 100% Polyurethane Frame On All Sides For Extra Long Filter Life
    • Washable and Reusable for Multiple Cleaning Cycles
    • Up to 47% increase in Flow
    • 25mm Deep Rounded Open Pleats / 27 Count
    • Progressive Bump Seal Design for a Perfect Fit
    Pro DRY S Media:
    This filter features 3-layers of progressive media to provide maximum flow with excellent filtration. The progressive layering of media allows the filter to flow at high levels even when dirty. The Pro DRY S non-oiled synthetic air filter requires no oils for maximum convenience.
    Rounded Open Pleats:
    aFe performance air filters use a rounded, evenly spaced pleat design which produces more useable filter surface area for increased flow and greater dust holding capacity.
    Progressive Bump Seal:
    This pliable sealing surface conforms to even the most uneven filter housing. This design eliminates the use of gaskets or sealants. The soft urethane construction always goes back to its original form so you will never compress the bump seal. This makes for a perfect filter fit and sealing surface every time.
    Full Urethane Housing:
    aFe Power performance air filters are constructed using full 360 degree urethane frames. This construction allows for a proper OE style fit with excellent filter strength.
    aFe Power OE replacement performance filters have a limited lifetime warranty.
    Fits:
    2015 Mustang EcoBoost L4-2.3L (t)
    2015 Mustang V6-3.7L
    2015 Mustang GT V8-5.0L
    Available here: http://www.southerncarparts.com/2015-ford-mustang-magnum-flow-filters-p-7557.html
    [​IMG]
    [​IMG]
    waited likes this.
  2. OP
    Southern Car Parts
    Gold Sponsor
    Vehicle(s):
    2015 6spd GT
    Dec 18, 2014
    Atlanta, GA
    350
    :thumbsup:
  3. wildcatgoal
    wildcatgoal @sirboom_photography
    Vehicle(s):
    TBD
    Feb 8, 2016
    6,597
    2,466
    0   0   0
    I use a aFe dry filter and have been happy with it. Snappier throttle. I did a dyno with it but I think that dyno may have been on the happy side. That or 409 HP in 4th gear on a MT with no tune is actually accurate... don't think so.
  4. MSMStannyl
    MSMStannyl Well-Known Member
    Vehicle(s):
    2015 Mustang GT Premium - Triple Yellow
    Jun 23, 2015
    Baltimore, MD
    718
    188
    0   0   0
    Did you do a before AND after? That definitely sounds "happy". Very, very happy!
  5. OP
    Southern Car Parts
    Gold Sponsor
    Vehicle(s):
    2015 6spd GT
    Dec 18, 2014
    Atlanta, GA
    350
  6. bjstang
    bjstang Well-Known Member
    First Name:
    Bill
    Vehicle(s):
    2016 GT Premiums a.k.a "Crazy Horse" & "Doll"
    Dec 2, 2016
    OK
    4,275
    6,156
    Garage Profiles:
    Rating:
    100%
    1   0   0
    +1, happy with ours! aFe Magnum Flow PRO Dry Air Filters 31-10255
Loading...
Share This Page
