-New cams with 1mm more intake lift and 2mm more lift on the exhaust side
-New cylinder heads with revised high-flow ports and slightly larger valves
-Mid-lock cam phasers to provide greater range of cam timing on the intake side
-A revised intake manifold with charge-motion control valves.
-The forged connecting rods from the current Boss 302 engine
-The forged balanced crank from the current Boss 302 engine
-Revised piston tops
-The valve springs from the current Boss 302 engine
-Standard oil cooler
I'm guessing that either the leaked power increase of 10hp and 6 lb-ft is bullshit or Ford is severely underrating this engine. It's basically going to have the Cobra Jet intake cams, Boss exhaust cams, Boss heads with bigger valves (that even the CJ did not get), Boss rotating assembly, and a new intake manifold. I can't see it having less hp than the Boss engine and really it should have substantially more.
