RPI Designs
- Nov 18, 2014
- Salem, Ohio
- Website
- www.rpidesigns.com
- 2015 Mustang GT - Test Mule
2015-2019 Ford Mustang Covercraft Noah All Weather Car Cover
https://www.rpidesigns.com/shop/item.aspx?itemid=5128
This 2015-2019 Ford Mustang Covercraft NOAH car cover is designed to fit all 2015-2019 Ford Mustangs. Do you need a car cover that can protect your 2015-2017 Ford Mustang from the hazards the outdoors? The NOAH Mustang Car Cover from Covercraft is the answer. Made in the USA by Kimberly Clark, the fabric weighs only 4.75 oz./sq. yd., so it's very easy to handle and fold. Noah Car Covers are made from a fabric that is the most breathable, but water resistant car cover on the market.
NOAH barrier fabric actually stops water, yet it "breathes" to allow any trapped moisture, seam seepage or condensation to easily evaporate. The unique construction process (patent pending) results in a cover with maximum all-weather protection...highly water resistant, dust resistant, UV resistant and breathable to make sure moisture and/or heat don't stay under the cover.
Protective Outer Layers - A bi-component spunbound, using sheath-core technology. The inner core is polypropylene for strength, with a polyethylene wrap for softness. A silver-gray color was selected because of its heat-resistant properties. The fabric is also treated with UV inhibitors for extended outdoor use.
Micro-Porous Middle Layer - The barrier layer is breathable film, a proprietary stretch-film technology developed exclusively for Kimberly-Clark. The film is stretched and subjected to a chemical process that creates microscopic holes smaller than droplets of water or dust, yet large enough to allow moisture vapor to escape. Soft, Paint-Protecting Inner Layer - A bi-component fabric made of polyethylene and nylon. This combination results in an exceptionally high strength-to-weight ratio, with the "soft touch" necessary for today's water-based paint finishes. The NOAH Car Cover ONLY comes in Silver. The color choice is by design...Covercraft chose silver for their premier outdoor cover because of Silver's abilities to reflect sun and heat away from your car. The NOAH Cover is about the best all-around outdoor protection you can get from a car cover and is only available as a Custom fit car cover (high-end car covers are always custom fit, if you want the best, never get a universal fit cover).
