2015-2017 Mustang V6 Airaid MXP Cold Air Intake Kit with Red SynthaMax Dry Filter
Discussion in 'V6 Bolt-Ons & Tunes' started by CJ Pony Parts, Sep 28, 2016.
Thread Status:
Not open for further replies.
  1. CJ Pony Parts
    CJ Pony Parts Well-Known Member
    Vehicle(s):
    A large variety of Mustangs across all generations
    Dec 21, 2015
    Harrisburg, PA
    1,290
    403
    0   0   0
    #1 CJ Pony Parts, Sep 28, 2016
    Just like any retail business, from time to time we get returns. A lot of times there is little to nothing wrong with the actual product and more often than not a customer just changes their mind. Luckily we have our eBay Store which will allow us to pass on great savings to people that aren't worried about a possible scratch or dent, maybe a missing washer, nut or even instructions.
    If a used, returned or discontinued item is posted on our eBay Store, we try to take as many photos as possible and explain what (if anything) is missing and/or damaged. Below is a perfect example of this.
    2015-17 MUSTANG V6 COLD AIR INTAKE KIT AIRAID MXP with RED SYNTHAMAX DRY FILTER
    Item condition: New other (see details)
    “There cold air kit was previously installed.”
    Original Product Listing:
    Airaid MXP Series Cold Air Intake Kit with a Red SynthaMax Dry Filter for all 2015, 2016 and 2017 V6 Mustangs.
    Airaid has pulled out all the stops for this new MXP Series Cold Air Intake Kit with a Red SynthaMax Dry Filter for 2015-2017 V6 Mustangs. The system of this kit is computer designed, giving you the maximum amount of airflow that you can possibly have. This means you'll see upgrades to your horsepower, torque, and fuel economy. Along with the red filter and its unique overall design, this cold air intake kit delivers increased performance and great looks that enthusiasts demand.
    Cold Air Kit Includes:
    - Cold Air Box with Plexiglass Window & Lid
    - Red SynthaMax Filter
    - Roto-Molded Intake Tube
    - Hump Hose
    - Stainless Steel Clamps
    - All Necessary Hardware & Installation Instructions
    Cold Air Kit Features:
    - Designed to Maximize Airflow
    - Creates a Smooth, Unrestricted Airflow Around Filter & Throttle Body
    - Draws Air from Factory Air Duct Location
    - Keeps Filter Isolated from Hot Engine Air
    - Increased Underhood Styling
    - Made in the USA
    - Easy, Bolt-On Installation
    This cold air kit from Airaid features a one-piece roto-molded intake box that is specifically designed for your 2015-2017 V6 Mustang. This box draws outside air from the stock air duct location while also having a unique shape that allows airflow to go all the way around the filter. The design of Airaid's intake airbox makes use of lid with a plexiglass window that enhances the underhood styling while also keeping the filter isolated from the hot air coming from your engine compartment. This also will make it much easier to keep tabs on the filter's condition.
    This kit also includes an roto-molded intake tube that connects the airbox assembly to the throttle body of your engine. Once installed, this tube will maximize airflow and provide a more smooth & unrestricted path for air to reach the throttle body. This kit will also supply you with the correct hump hose, stainless steel clamps and all of the necessary hardware to properly install this kit to your 2015-2017 V6 Mustang. The installation process is very easy, as you'll just need to bolt it on and go.
    SynthaMax Filter Features:
    - Inner & Outer Layer of Wire Mesh
    - Unrivaled Filtration Efficiency
    - Won't Deform or Collapse Under High Air Flow
    - Washable & Reusable
    - Oil-Free Maintenance
    - 100% Synthetic
    The Red SynthaMax Dry Filter has an inner and outer layer of wire mesh for more durable support of filtration. Washable & reusable, Airaid's filter will also not crumple or collapse even under a high amount of airflow. 100% synthetic, this filter is easy to handle and requires zero oil maintenance. The filtration efficiency of this SynthaMax filter is unmatched in the market, making for the cherry on top of this fantastic upgrade.
    *No tuning is required with this system; however, this intake has also proven to maximize the benefits of aftermarket tuning.
    THIS IS A FINAL SALE THERE WILL BE NO RETURNS OR REFUNDS ON THIS ITEM
  2. OP
    CJ Pony Parts
    Vehicle(s):
    Dec 21, 2015
    Harrisburg, PA
    1,290
    403
    0   0   0
Loading...
Thread Status:
Share This Page
