RPI Designs
- Nov 18, 2014
- Salem, Ohio
- Website
- www.rpidesigns.com
- 2015 Mustang GT - Test Mule
2015-2016-2017 Mustang Mustang GT Performance Aluminum Radiator $547.50
Cool down your Coyote. The Mustang GT’s Coyote engine is a feat of engineering, but every engine needs to maintain proper engine temperatures. After winding the engine out to its 7,000 RPM redline during some hot laps at the track engine temps will start to rise. The Mishimoto Mustang GT radiator is up to the challenge of keeping temperatures down, even after consecutive laps with the pedal mashed to the floor.
The 52mm, 3-row core is a massive upgrade over the stock radiator. With a 77% increase in coolant capacity over the stock performance package radiator, overheating won’t be an issue. Launch your GT down the strip as much as you want, and you’ll have the peace of mind that coolant temperatures will be right where they’re supposed to be. This high-quality Mustang GT radiator is backed by the Mishimoto Lifetime Warranty to ensure only the best of the best.
Direct fit for 2015+ Ford Mustang GT, standard and performance pack models
Core designed for maximum efficiency over the performance package radiator
52mm, 3-Row core
129% increase in coolant capacity over the stock radiator
26% increase in coolant surface area (tubes) over the stock performance package radiator
55% increase in air surface area (fins) over the stock performance package radiator
Fully brazed aluminum core
Fits manual and automatic vehicles
TIG-welded to perfection
Includes Magnetic Drain Plug
52mm, 3-Row core
