2015-17 Mustang Mishimoto Coolant Expansion Tank Black Aluminum
Discussion in 'Miscellaneous' started by CJ Pony Parts, Feb 2, 2017.
Thread Status:
Not open for further replies.
  1. CJ Pony Parts
    CJ Pony Parts Well-Known Member
    Vehicle(s):
    A large variety of Mustangs across all generations
    Dec 21, 2015
    Harrisburg, PA
    1,290
    403
    0   0   0
    #1 CJ Pony Parts, Feb 2, 2017
    Just like any retail business, from time to time we get returns. A lot of times there is little to nothing wrong with the actual product and more often than not a customer just changes their mind. Luckily we have our eBay Store which will allow us to pass on great savings to people that aren't worried about a possible scratch or dent, maybe a missing washer, nut or even instructions.
    If a used, returned or discontinued item is posted on our eBay Store, we try to take as many photos as possible and explain what (if anything) is missing and/or damaged. Below is a perfect example of this.
    2015-2017 Mustang Mishimoto Coolant Expansion Tank Black Aluminum
    Item condition: New other (see details)
    "This has a few very minor scratches."
    Mishimoto Black Aluminum Coolant Expansion Tank for all 2015, 2016 and 2017 Mustangs.
    Create an upgrade in looks and performance for your 2015-2017 Mustang by purchasing Mishimoto's Black Aluminum Coolant Expansion Tanks. The plastic stock coolant tanks are just not up to par and are prone to failure from years of dealing with the variety of temperature changes. This aluminum tank will not only fix that issue but will also add a touch of style under the hood of your S550.
    Features & Benefits:
    - Direct Fit for 2015-2017 EcoBoost, V6 and V8 Mustangs
    - TIG-Welded, 100% Aluminum Construction
    - Black Powder Coated Finish
    - Internal Baffles Prevents Coolant from Splashing During Aggressive Driving
    - Maximum Durability
    - Prevents Air Entry Into Coolant System
    - Includes Sight Tube to Monitor Coolant Levels
    - Fits with Original Overflow Cap
    - Overflow Nipple on Fill Neck Permits Installation of Added Overflow Reservoir
    - Comes with Overflow Hose, Worm-Gear Clamps & Mounting Hardware
    - Simple Installation
    This coolant expansion tank from Mishimoto features an aluminum construction that has been TIG-Welded to be a direct fit for your 2015-2017 EcoBoost, V6 or V8 Mustang. The 100% aluminum material will provide the maximum amount of durability & longevity to handle the constant temperature transitions. This tank also has a black powder coated finish to truly stand out in your Mustang's engine bay. Mishimoto makes sure to include a sight glass to let you properly monitor your hot & cold coolant levels.
    The true highlight of this coolant tank is that internal battles that will prevent your coolant from sloshing around during your aggressive driving situations. These battles will also prevent any air entry into your coolant system, as well as making sure there isn't any coolant starvation from the overflow ports to the engine.
    This coolant expansion tank is also designed to work with your original overflow cap and comes with an overflow nipple on the fill neck. This overflow nipple will let you add on another NHRA-mandated overflow reservoir. Mishimoto also makes sure to include a new overflow hose, three worm-gear clamps and mounting hardware to easily install your new expansion tank correctly in about an hour.
    Please Note: After a few hot & cold cycles, it is recommended that you check the sight glass on the side of your new expansion tank to confirm your coolant levels are accurate.
    Tech Tip: 22in-lbs is recommended for your worm-gear clamps. These clamps have an operating range of 18-27 in-lbs. so make sure you do not exceed the maximum torque rating of 27 in-lbs.
    THIS IS A FINAL SALE THERE WILL BE NO RETURNS OR REFUNDS ON THIS ITEM
    notstok5.0 likes this.
  2. OP
    CJ Pony Parts
    Vehicle(s):
    Dec 21, 2015
    Harrisburg, PA
    1,290
    403
    0   0   0
  3. OP
    CJ Pony Parts
    Vehicle(s):
    Dec 21, 2015
    Harrisburg, PA
    1,290
    403
    0   0   0
Loading...
Thread Status:
Share This Page
