TheLion
1. You do NOT NEED an oil separator, but it won't hurt as long as your willing to empty it regularly. A few people reported pinging that was resolved by using an oil separator, but most don't have any issues at all. If you have poor fuel quality AND are limited to 91 or at a higher altitude I'd imagine an oil separator would be more valuable to you than it would to most. Since the second generation 5.0 is port injected there's no benefit other than reducing possible fuel dilution. Oil vapor or droplets in the combustion chamber have proven time and again, both NA and FI, to cause higher occurrences of knock. The ECU will keep things running safe, but you may loose some power by forcing it to run more conservative timing should it occur.I'm like 95% sure I'm pulling the trigger on a PP2, but some of the comments here have me hesitating.
FWIW: I have a stock 2017 Mustang GT with 3.55 gears. I don't track my car at all, and don't really intend to. However, I *allegedly* do play a bit from a dig on stoplights and from a roll on highways. I'm not trying to get this car to fly, but it'd be nice to at least be competitive vs. stock Camaro SS, and not to get destroyed off the line by freaking modded Subarus (though I always blow right past them soon after).
A couple of questions:
- Do I *need* an oil separator if I'm installing a PP2?
- Did you notice any sound differences based *just* on the addition of a PP2? I've seen mixed reviews on this (some saying the car becomes a bit louder, some say there's no difference).
- Would you recommend pairing the PP2 with an aftermarket exhaust system, or does it really not matter?
- Anything else I should know before I pull the trigger?
I'd wager an after market oil cooler and better NOAC rated oil would be more beneficial than an oil separator. Oil isn't going to boil off if it doesn't get hot enough, if it's not boiling off then there's no need for an oil separator that requires you to empty it! A more robust oil and an oil cooler allow for an increase margin before any boil off would occur.
I did that with my Ecoboost and it worked very well when so many others were saying you "need a catch can", I was making 315 WHP on the dyno in 4th gear with just the Ford Performance Power pack, an inter cooler (ATM) and thermostatic oil cooler (Mishimoto).
2. Sorry, can't help there as I won't have my PP2 until august...
3. If you go after market exhaust, most of your gains are in weight savings, especially with the Ford Performance exhaust by Borla, which is 30 lbs lighter, but there are a couple of HP to be squeezed out at higher RPM (maybe 5-7 on average) mostly due to the "suite case" being traded for an X pipe which does flow a little better than the stock "suite case" on most of the after market exhausts.
4. You might want to consider a higher efficiency coolant or coolant additive especially if you don't have a Performance Package car with the thicker radiator. Amsoil makes a full temperature range coolant additive that lowered temps in 50/50 mixture coolant by about 8F. PP2 is pushing more power and revving higher, there's going to be a little more heat. It doesn't just lower average temps, it also helps decrease warm up and cool down times. Once you start to build heat, the more conductivity you can provide to the radiator, the faster you can shed that heat and cool down.
If you keep things in the optimal temperature range, you'll get the full timing that the PP2 ECU software is willing to give you more often and a small boost in conductivity of the coolant will help off set some of the added heat. Some track guys have used this successfully to help keep temps a little lower, there's absoulutely no reason it can't be used in a daily, in fact it will help reduce cold start wear by bringing the oil temps up faster especially if you have a PP radiator and water to oil cooler that PP cars come with: https://www.amsoil.com/shop/by-product/other-products/antifreeze/dominator-coolant-boost/
