2014 Brembo Calipers on 2016 GT
timd38
Hudson WI
GT/CS C6 Corvette
Does anyone know if a 2014 Brembo caliper will fit a 2016 GT with base 4 piston calipers?
Thanks!
timd38
timd38
Hudson WI
GT/CS C6 Corvette
Can I ask why?
2014 had 15" rotors and the 2016 base is 15" rotors, so use 2014 Brembo calipers and no need to change a bunch of stuff. Plus I know of a pair of new 2014 calipers are.
Plus I want to use the spare tire.
Jeff's FRC
Lakemoor, IL
Jeff
2020 Mustang GT
The base calipers are just as good as the 14 Brembo's. You won't gain anything from this swap other than a brembo logo. I'm not sure they will bolt up either...
If you're looking for more braking power, do a pad and fluid swap.
plc268
Central Texas
Patrick
2015 Mustang GT Premium Race Red
Probably more for an aesthetic change, I'm guessing. As far as I know, the 14 brembos are near identical to the 15 gt brakes, except that the 15 brakes aren't made by brembo.
timd38
timd38
Hudson WI
GT/CS C6 Corvette
Thanks all! Doesn't sound like the juice is worth the squeeze.
Niz55
Us
17 GT350
2014 and the 2015 base gt never had 15" rotors only PP GT.
plc268
Central Texas
Patrick
The only ones that I'm aware of being 15" where the gt500 brakes, which look similar to the PP GT brakes.
