- Nov 30, 2015
- Wellington Florida
- Ford
On the 5th day of Christmas, Lethal gives to you 20% OFF of all McLeod Racing clutch kits & accessories!!
Today only (and Friday, Dec. 21) we are giving you 20% OFF of all McLeod Racing parts. No coupon code is needed, just add to cart & your discount is reflected on the total!
Need help deciding which clutch you need? Look no further. We've run a McLeod clutch kit in every one of our manual cars since our older GT500s, including our 9-second 2015 Mustang GT. We're also one of McLeod's largest dealers. Check out the video below and let Jared give you the 411 on the different options for clutch kit & slave cylinders so you make sure that you are getting (and saving on) the correct setup!
Get all that? If not, give us a shout! Any of our reps will be glad to point you in the right direction.
Here's a rundown of some options for your 15+ Mustang GT:
2015-2017 Mustang GT
Solid hub RST with Aluminum flywheel: 6335825
Solid hub RXT with Aluminum flywheel: 6335825M
Solid hub RXT HD with Aluminum flywheel: 6335825HD
Sprung hub RST with Steel flywheel: 11176975
Sprung hub RXT with Steel flywheel: 11176975M
Sprung hub RST with Aluminum flywheel: 11176975A
Sprung hub RXT with Aluminum flywheel: 11176975MA
We know there are rumors & urban legends that the RXT will destroy your MT82 right away, however we’ve run an RXT in ALL of our cars, including multiple MT82s, and we have not had an issue. These cars were NOT babied, either.
2018+ Mustang GT
RXT with Aluminum flywheel: 6333825M
And for the automatic guys... McLeod introduces their newest addition!
10R80 Transmission Friction Plate and Steel Kit: 88098
Got a trans swap? We've got you covered!
2011-2017 Mustang with a TR6060 Swap
If you swap a TR6060 into your car, we will basically treat it as a 2010-2014 Shelby GT500. Here’s what you will need from McLeod:
RST: 6975-07
RXT: 6975-07M
RXT HD: 6975-07HD
You will also need to purchase a shorter slave cylinder (SKU: DR3Z-7A508-A)
For the full 19 Days of Christmas lineup, click here!
