No to much, its 325/380 vs 480/420.There really is no point in Ford putting the 2.7 or 3.5TT into the Mustang until the 5.0 is a thing of the past. If you limit the power of the 2.7, then you're in 2.3 territory. If you keep the 2.7TT as is, then you're approaching 5.0 territory. If you boost it at all, then you're going to push the 5.0 to extinction (which, let's be honest, is on the distant horizon anyway).
There will come a day when a low displacement TT will very likely fall under the hood of a Mustang. A hybrid 2.7TT would make a wicked ride, especially if they figured out an AWD platform. But it's not going to happen soon - from an economics standpoint, it can't co-exist with the 5.0.
In its current form, you're correct, the 2.7 doesn't encroach too much on the 5.0. But also, in its current form, the 2.7 gives Ford no incentive to spend the cash on R&D to put it in the Mustang, as 325/380 is barely an improvement over the 2.3 (and with added weight, perhaps not an improvement at all).No to much, its 325/380 vs 480/420.
I can imagine that if the 5.0 is replaced with the 5.2 then the 2.7tt or 3.0tt could end up as an EB option.
MPG will be an issue though. I have a 400HP 3.0TT in my Q50, but it is REALLY hard to get over 15MPG in my short, stop/go heavy commute to/from work. The Mach1 gets about 17-18 in the same commute.
I was just wondering if it is possible for Ford to put the 2.7L on the next generation Mustang Ecoboost? I am no technical person but i know that some engine configuration can't fit in certain chassis or car types.
Yeah, well when you have no other option, we'll see.If the V8 goes away - I go away as a buyer.
They should be boosting a V8, not a 6 or 4.
And then FORD will get 10 other buyers for the turbo'd V6, that didn't care for the V8 in the previous generation mustang.If the V8 goes away - I go away as a buyer.
