Advertisement
19 vs 18 inch by 10inch wide for track??
Caballito
Posts
311
Sacramento, ca
2017 Mustang GT Base
Hi guys, so, like to see what u guys recommend for track work 18x10 or 19x10?? If u guys have some inexpensive
Tried and truth wheels you guys use send me a link i would appreciate it thanx.
Ewheels
Posts
512
SoCal
Eric
2018 GT PP1, 2009 CBR600RR
How competitive are you trying to be? 19" will have more tire options but 18" will be lighter weight and lower rotational inertia.
My suggestions:
18" - Apex wheels (EC7 or SM10)
19" - Also Apex but any of the LMR SVE flow formed wheels are solid for the price
Caballito
Posts
311
Sacramento, ca
My suggestions:
Well i want this for the track only so are the 18” better because of the lighter weight etc? Any offset or measurement i have to worry about or the rims u recommended already good to go? Also how wide of a tire can i out them? Thanx
NightmareMoon
Posts
2,975
2016 Mustang GT PP
Pick your tires first. Some of the good ones won’t come in 18” sizes and mustang diameters. Others are not be available in 19”.
Ewheels
Posts
512
SoCal
Eric
Ewheels
Posts
512
SoCal
Eric
Interesting, what so u use for track?
For wheels and tires, you should find what fits your budget first. There will always be better and more expensive options.
I use SVE SP2 wheels (19x10). I got a set on sale for $800. For tires, I use Bridgestone Potenza S007A, 285/35/19. Got a set of 4, mounted and balanced for $900. Are these the best options? Not by a long shot but they work well for my skill level and budget.
Advertisement
Flyhalf
Posts
623
CA
www.youtube.com
Alessandro
Mustang GT 18 10speed auto PP1
I have for the track
#2 set 19x11 LMR.
#1set apex wheels 18x11(one of the few to clear the 6 piston brakes)
All +52mm offset (so you can rotate all around for better wearing)
Using a 25mm spacer (opmustang .com)
Lomger studs(to accomodate the 25mm spacer)
Open lugnuts (opmustang.com)
And alsonI suggest the camber plates. For better fitting under the fenders and performance.
Our cars love big tires(possible 305) and lots of camber.
Ps the different in weight is 1lbs btw 19x11 and 18x11. The are flow formed
Grintch
Posts
1,633
Hunstville
2015 GT PP
What are the good ones? O what tires and rim combo u recommend
They are all good, for different things. This why you need to choose the tire first.
Slicks
Semi-slick R compound
Streetable R compound
200TW Extreme Performance Tire
300TW Max Performance tire
18s are generally better for the first two (better tire selection), and 19s better for the last two.
Meraki Autoworks
Gold Sponsor
Posts
21,180
Orange County
www.merakiautoworks.com
Josh
2018 GT PP
Do it right the first time and get some Titan7 18s for your track setup.
$2100 for fully forged wheels is a steal.
https://titan-7.com/collections/whe...ed-split-5-spoke-wheel?variant=32122955825240
https://www.mustang6g.com/forums/th...heels-affordable-forged-wheels.127705/page-11
Here's a customer with a set of 18s on his GT. Running a 275/40/18 tire setup all around. No rubbing or issues.
If you want to run a bigger tire you would need to utilize spacers but we also have a track mustang with 305s.
Let me know if you have any questions or you would like to get a set for yourself!
Feel free to text me at 213 394 2886!
-Josh
Caballito
Posts
311
Sacramento, ca
Slicks
Appreciate ur post, am thinking i will be doing 300tw firs then no more than 200tw.
With that being said any inexpensive rim that wont break at the track that u can recomend?
Grintch
Posts
1,633
Hunstville
2015 GT PP
The various SVE wheels in 19x10 are great bang for the buck. Pick the design you like best, I think they are all within a pound or so of each other. I would give a slight preference to the ones availible in +35 vs +40 offset.
I like the Flow One wheels Tire Rack carries as well.
Caballito
Posts
311
Sacramento, ca
Links??
Advertisement
Advertisement
Advertisement
