Should just be a direct replacement. It's calipers, pads, and lines. The lines are cut up higher so they can be used, just have to unbolt it. I just used my stock lines when upgrading to Brembos and haven't had any problems, I'm not sure if it works the same on ecoboosts.Is this everything an ecoboost owner would need in order to upgrade from the standard brakes? I don't have a performance pack, just the premium model.
I did a bunch of research last night and it looks like it should be a direct swap. Do you have all 4 or is it just 2?Should just be a direct replacement. It's calipers, pads, and lines. The lines are cut up higher so they can be used, just have to unbolt it. I just used my stock lines when upgrading to Brembos and haven't had any problems, I'm not sure if it works the same on ecoboosts.
PM'edBump
