18 inch wheels? On 2019 PP1 GT with Brembo brakes?
Discussion in 'Wheels & Tires' started by got_stanged, Oct 12, 2019.
  1. got_stanged
    got_stanged Member
    Vehicle(s):
    2019 Mustang GT Premium, Shadow Black, 401A, Performance package, Active Exhaust & Enhanced Security
    Mar 10, 2019
    Cambridge
    Looking to get winter tires on my 2019 GT PP1 with Brembo. Would 18 inch wheels clear? Thinking of getting the WS90. 235 50 18. Thank you
  2. kent0464
    kent0464 Well-Known Member
    First Name:
    Kent
    Vehicle(s):
    1983 Ford Ranger, 1986 SVO Mustang, 2017 Mustang GT PP, 2017 F150 3.5 Eco
    Aug 31, 2019
    Virginia
    399
    199
    Garage Profiles:
    A wide variety of 18’s do fit, I posted a list of those I’ve physically tried myself in a thread in the tire and wheel category....(not sure how to link it).
    The picture is of my 17 Mustang GT W/PP with 18 x 10 FC19 OE Racing Wheels, costing $124 ea. purchased of eBay.
    With the amount of snow you guys get up there, a wide tire isn’t going to help, so an 18 x 8.5 would be a better option and a tire with a higher side wall would be best. If it’s acceptable in your locality a set of studded tires should assist in keeping you car safe.73B0E324-114C-42BD-92D4-DADC010A81C4.jpeg
  3. Bikeman315
    Bikeman315 Well-Known Member
    First Name:
    Ira
    Vehicle(s):
    2019 Mustang GT/CS
    Apr 12, 2015
    Myrtle Beach, SC
    5,836
    4,482
    Occupation:
    Retired
    0   0   0
    Here you go.....
    https://www.mustang6g.com/forums/threads/18”-wheels-on-pp-for-the-budget-minded.129604/#post-2678167
  4. Copperhead73
    Copperhead73 Well-Known Member
    First Name:
    Derrick
    Vehicle(s):
    2019 Mustang GT Premium Convertible PP1, A10, Mag, B&O, A/E, S&S
    Oct 13, 2019
    Knoxville, TN
    266
    260
    Occupation:
    HR Analyst
    0   0   0
    Similar question. I have a line on 18x8 2018 GT (non PP) take offs. I would like to use them for winter. Anyone know if they will fit a 2019 PP1?
  5. ModularKid21
    ModularKid21 Well-Known Member
    Vehicle(s):
    ‘15 GT
    Nov 17, 2018
    715
    562
    Garage Profiles:
    They won’t fit. The aftermarket 18” wheels that do fit feature a different barrel and spoke design. Check the link in post #3 for a list of some of the 18” wheels that will fit. The only factory non pp wheels I can guarantee fitment of are the 20” foundry wheels as I’ve had them on my car
    Copperhead73 likes this.
  6. Copperhead73
    First Name:
    Derrick
    Vehicle(s):
    Oct 13, 2019
    Knoxville, TN
    266
    260
    Occupation:
    HR Analyst
    0   0   0
    Well, damn. Thanks for the info. Bummed, but not as much as if I had bought them!
  7. wsfrazier
    wsfrazier Well-Known Member
    Vehicle(s):
    2019 GT PP1 M6 401a
    Jun 8, 2015
    Pittsburgh, PA
    345
    68
    0   0   0
    Even with a 1" spacer? I test fit some base 18" take offs on my 19 GT PP car, and it only started to rub the caliper when I tried to push the wheel on the hub, but it fit over the lugs a good bit. Wondering if a 1" spacer would be just enough.
  8. ModularKid21
    Vehicle(s):
    ‘15 GT
    Nov 17, 2018
    715
    562
    Garage Profiles:
    Depends on where it’s rubbing. Do the spokes touch the face of the caliper? Or does the barrel of the wheel touch the back side of the caliper? If the contact is only between the spokes and the face of the caliper, a spacer would do the trick
  9. fatbillybob
    fatbillybob Well-Known Member
    Vehicle(s):
    '19 GT pp1 Orange
    Apr 1, 2017
    SoCal
    253
    93
    0   0   0
    Can someone with apex 18x11 wheels post a sort of close picture of what the wheel looks like and the proximity to the caliper with the 1" spacer? Does anyone know what happens to the increased scrub radius? Is this a problem?
  10. kent0464
    First Name:
    Kent
    Vehicle(s):
    Aug 31, 2019
    Virginia
    399
    199
    Garage Profiles:
    Apex wheels are guaranteed fitment for S550 they have a ton of pics on their site.
    If it helps I tried another brand of wheel that was 18 X 10 with 42 offset, the rear sat flush on my car the front needed a 1 1/2” spacer to sit flush. If you want to run square for ease of rotation then you’ll probably need to run a spacer up front.
  11. ModularKid21
    Vehicle(s):
    ‘15 GT
    Nov 17, 2018
    715
    562
    Garage Profiles:
Loading...
Share This Page
