'18 GT MT82 Gear Ratios
nastang87xx
nastang87xx
Wisconsin
2016 GT350 Track Pack
I'm an idiot...mods, please delete.
EDIT: But now, don't delete since becausebiggeridiot. I didn't find my answer. :mad:
Ebm
North Carolina
Guy
'14 GT
3.55, 3.73
Cool Story Bro
nastang87xx
nastang87xx
Wisconsin
That's diff ratio. He's talking 1st, 2nd, 3rd, etc.
What were the ratios that you found nastang?
Actually I thought I found the post...and now I didn't. So yeah, still open. I do remember that 4th is 1:1 now and I wanted to find out what the rest of the ratios were from 1 - 3. So yes, you are correct, the trans ratios, not the diffs.
UAmach1
Bullitt Hopefull
PA
Ford/INFINITI
cosmo
Michigan
2005 Mustang GT
I have a fear they're bringing the ratios of the MT82 down to the Tremec's, which would be unfortunate. I like the shorter gearing with relatively high HP/low torque engines.
I'd like them to keep the short gearing.
williamwally
chicago
06 gt
Maybe the new longer MT82 ratios will bring steeper rear gearing back into vogue.
Ebm
North Carolina
Guy
'14 GT
Wrong answer.
Learn to read Bro. A MT-82 isn't a rear end.
Final Drive Ratio bro. It depends on the drive ratio of your transmission, the number of teeth on the pinion gear in your differential and the number of teeth on the spur gear in your differential. He could have been talking about either.
DickR
Raleigh
http://www.mustang6g.com/2018-Mustang-eSourceBook.pdf
Transmission ratios on page 130 of the pdf.
Same as current manual ratios so they may be another "not correct" facts like the PP2 wheel width in the order guide. Especially given that they conflict with other statements about the ratios. Wait and see.
The 10A ratios are consistent with both the F150 and the Camaro ZL1 10 ratios.
cosmo
Michigan
2005 Mustang GT
No, the title of the thread is MT82 Gear Ratios.
Yay. I hope so.
GT_Dave
NE Illinois
1970 Mach 1 408EFI , 2016 GT350
GT M- 82 forward ratios are the following
1 is 3.66
2 is 2.43
3 is 1.69
4 is 1.32
5 is 1.0
6 is .65
Grimace427
NoVA
2011 Mustang 5.0
1 is 3.66
2 is 2.43
3 is 1.69
4 is 1.32
5 is 1.0
6 is .65
Those are the current '11-17 gear ratios.
That would make for increased driveshaft RPM's which is a bad idea. There are enough people complaining of driveline vibrations as it is.
