Kona 18
So a few weeks back I ordered @Edelbrock Tech's supercharger for my 2018 and just got it all unboxed...
Everything was boxed pretty damn good, it shows up strapped down on a pallet so the chances of it getting damaged during shipping is almost none. The boxes they use are also pretty tough, the cardboard is twice as thick and most boxes I work with .
Here is a closer look at the head unit, you can def see the opening on the blower is much larger now allowing more less restriction to the rotor inlet...
The intercooler is pretty beefy on these things too, I haven't taken the lid off but I see it through every port on the lower manifold, def a good quality core in there. The core has a pretty good fin density, and they are staggered in there so it's not just a straight through design, this will lead to cooler IATs
This is only a few of the things that showed up with the kit, since the rest is still in it's boxes. The fuel rails have ORB 6 inlets/outlets and each rail has 2 ORB 6 ports on the side. You are to use the included adapter on 3 of those ports, 2 are for the fuel quick connects, 1 for the OE temperature/pressure sensor, and the fourth is plugged.
One thing to point out is even the tuner kit comes with spark pugs, I was not aware of this and bought a set of NGK 6510's in preparation, how ever it seems that was not necessary, these plugs all showed up pre-gapped at .029".
