16' Mustang GT convertible subwoofer
Klement1
Arizona
16 Mustang GT convertible
I have a premium car with no sub but have the shaker system. Any subwoofer ideas for the trunk? With the upper rear deck completely sealed to house the top wanted to hear success stories/ideas. No one seems to make a side mount rear woofer yet like last gen. Any help is appreciated!
kingofsting
NYC
2016 Mustang GT Shadow Black / Redline Interior
I have a 401A coupe; it came standard with the OEM woofer, which I replaced with a Kicker sub powered by a compact JL amp. You could do something similar
Klement1
Arizona
Kool. Could you share some pics? I have never seen the OEM.
Rich of So Cal
So Cal-IE
Rich
2015 GT Prem/auto - triple yellow convert
I have a convertible with stock subwoofer in the trunk. works fine. btw the lower part of the rear seat is exposed in the trunk. the top sits in a compartment that does not go all the way down. I know this because I put Katzkins on my seats and when I replaced the rear seat I could see the new material in the trunk. but anyway, it is not a problem for the subwoofer to be in there. mine mounts on the right side. I believe the hardtop version is a little different and will not fit the same.
Klement1
Arizona
Thx. I noticed the seat material as well. Great news for letting bass responses through. Only box designs I can find are like is and isolate the front from the back. Would work fine for a coupe where the top deck is vented to the trunk but the convertible is all metal above housing the top.
http://www.ebay.com/itm/262644726487?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
Klement1
Arizona
Custom enclosure
Going the custom route. Will fab a dual 10" enclosure to fire down and center behind back seat that will fire through it and maximize output in the car as well as conserve truck space. Will update with pics.
shawnd
Perth
Future Ford Mustang Vert in Ruby Red
Keen to see the pics as I will be doing something similar when I receive my GT Vert.
prj_tchalla
Georgia
2016 Mustang 2.3L Ecoboost Convertible
How the custom subwoofer install go
Just checking to see how the custom subwoofer installation went?
Klement1
Arizona
Phase one of the system upgrade for my 16' Mustang GT convertible, Rockford Fosgate T2T-S (Titanium power series tweeters) replacing the stockers in the pillars, Rockford Fosgate T750X1BD 750 continuous (birth certificate with the amp proves 978 watts, WOWZA) watt mini chassis amp on the custom dual 10" subwoofer in the wheel well with two Rockford Fosgate R2 10" subwoofers. The Rockford T1 slims are the next upgrade to the R2's but I wanted to hear the difference between them. The R2's are super efficient and pound while being relatively shallow for a full frame sub-woofer.
The Mustang convertibles are a challenge for trunk space if you want to have anything else in there too! Lol. In the wheel well is an awesome solution then use Velcro to hold the air compressor on the oem carpet to save your butt if you get a flat... #RockfordRocks Rockford Fosgate
Phase two - The NEW Rockford DSR-1 that will give me full control over the factory head unit and amplifiers BEFORE the amps, 8 channel signal processor, add time alignment, 231 bands of parametric eq, level controls plus more WITH a tharness so i can put back to stock later, AND has a killer APP to control her via bluetooth, , T400X4ad amplifier for the highs/mids and the T1 slim subwoofers..
Klement1
Arizona
Here is a pic of the beast and the tweeters in the oem locations.
I tried a few different enclosures but by far response and saves the space is in the wheel well. Call, text or pm me if you have any questions. The new Rockford DSR1 works awesome on the oem head unit.
prj_tchalla
Georgia
Rockford vs JL Audio?
Very nice install man! I had thought about doing either wheel well or both side of the trunk where the factory subs come in.
I was thinking about using the JL audio shallow mount subs. Why did you go with the Fosgates vs. JL?
Klement1
Arizona
Thx! The Rockford’s took a smaller air space (only .5 cubic foot each) and were more efficient (the R2’s are 3 dB louder with the same power than the W0).. both are good solutions but for our wheel well the R2 is the best solution.
Keeping the woofers firing in the same direction will produce more output than if they were firing at one another. Have to be careful with too much cancelation when using in each side panel firing to the center.
Without fiberglassing Custom corners you can get 1.2 cubic feet and keep the height low enough to allow the factory cover to lay on top.
That’s perfect for two 10’s sealed or a single 12 ported. The 10’s will have the most output (cone area) but the 12 sounds awesome too.
Call or text me if you or anyone has questions 772 408 3169. Alvin
CHeYeNNe71
Arizona
Cheyenne
2017 Ecoboost Premium
I'm not sure if you're on here anymore, but I just picked up a 2017 Vert and looking to do something like this. Any chance you have the measurements of the box? I also see you're local in AZ.
musclesoh92467
Hemet ca
Eric
2016 mustang
Very nice what line out converter did you use ? Eric
stone36441
United States
2017 mustang gt
Hello I am thinking of getting the Rockford fosgate T2652-S components for my 2017 and was curious if you had to do any modifications for the tweeters? Thank you
