15 Gen 4 Whipple PBD Cal...What will it make?
Discussion in 'Forced Induction - 5.0L V8 Engine' started by Roh92cp, May 27, 2019.
  1. ahl395
    ahl395 Well-Known Member
    First Name:
    Allan
    Vehicle(s):
    Dec 30, 2015
    2,741
    1,129
    Rating:
    100%
    1   0   0
    Wow, if you were able to pull out that much meth and still keep the same timing you were definitely spraying too much. Surprised you didnt have misfires but that could definitely have hurt your power.
  2. OP
    Roh92cp
    Roh92cp Well-Known Member
    First Name:
    Shawn
    Vehicle(s):
    OW GTPP Whipple
    Jun 27, 2015
    Fort Kent Maine
    2,862
    1,122
    Rating:
    100%
    4   0   0
    Could have and we will see what happens next time around. With the BAP and 72’s I needed the extra meth to keep the AFR’s in check. I’m solid now with the FORE setup.
  3. OP
    Roh92cp
    First Name:
    Shawn
    Vehicle(s):
    OW GTPP Whipple
    Jun 27, 2015
    Fort Kent Maine
    2,862
    1,122
    Rating:
    100%
    4   0   0
    Could have and we will see what happens next time around. I needed the extra meth to keep the AFR’s in check, but now I’m solid with the FORE setup.
  4. Will@Whipple
    [email protected] Well-Known Member
    First Name:
    William
    Vehicle(s):
    Mustang
    Nov 10, 2015
    Fresno,CA
    50
    64
    0   0   0
    Have you had a chance to check your catalytic converter's ? Your showing many sign's of plugged converter's and I will also agree the compression readings of 245 seem a bit much from my experience.
    Roh92cp likes this.
  5. OP
    Roh92cp
    First Name:
    Shawn
    Vehicle(s):
    OW GTPP Whipple
    Jun 27, 2015
    Fort Kent Maine
    2,862
    1,122
    Rating:
    100%
    4   0   0
    HI Will, thanks for chiming in. I have long tunes and no CATS, bulges you see in the mid pipes are resonators for visual effect of cats.
    The compression check I conducted was with fuel pump fuse and injector pulled. Throttle was held open with foot to the floor and I let it crank for the full cycle 11 pumps I counted. I don't know why it would have read high doing it like that with engine cold.
  6. Will@Whipple
    First Name:
    William
    Vehicle(s):
    Mustang
    Nov 10, 2015
    Fresno,CA
    50
    64
    0   0   0
    Ahh I see, very slick :)
    Is there any excess oil consumption with your engine ?
  7. OP
    Roh92cp
    First Name:
    Shawn
    Vehicle(s):
    OW GTPP Whipple
    Jun 27, 2015
    Fort Kent Maine
    2,862
    1,122
    Rating:
    100%
    4   0   0
    There is some, about a quart in 3k.
  8. JRodSan
    JRodSan Well-Known Member
    Vehicle(s):
    Grabber Blue GT
    Mar 25, 2015
    Central Florida
    163
    133
    Rating:
    100%
    1   0   0
    Which resonators? Any sound clips?
  9. OP
    Roh92cp
    First Name:
    Shawn
    Vehicle(s):
    OW GTPP Whipple
    Jun 27, 2015
    Fort Kent Maine
    2,862
    1,122
    Rating:
    100%
    4   0   0
    Sorry no sound clips yet, I just got generic 3" resonators, don't remember the brand.
    JRodSan likes this.
  10. stang17
    stang17 Well-Known Member
    Vehicle(s):
    2017 GT Premium PP
    Jun 5, 2016
    Wilkes Barre, PA
    445
    104
    Rating:
    100%
    1   0   0
    Did you ever hit the dyno again? Curious what your most recent numbers are. I went with Rob/PBD for tuning my new 11:1 aluminator, 95 lb injectors, and BAP. I make about 30-40 less hp and tq than I did with my previous modified whipple tune, but still managed to pick up a few mph in the quarter. PBD tune also drives much better at partial throttle than the Whipple tune.
    I did go with a different clutch/flywheel setup, stage 3 caliber mt82, and added exhaust resonators , which all could have played some part with the numbers being lower.
    With 3.625 pulley, 22.5 timing, 93 octane + 1 full bottle boostane shot, 741 whp and 554 ft lbs . 20191002_165552.jpg
  11. OP
    Roh92cp
    First Name:
    Shawn
    Vehicle(s):
    OW GTPP Whipple
    Jun 27, 2015
    Fort Kent Maine
    2,862
    1,122
    Rating:
    100%
    4   0   0
    I just got it done this past week. I wanted to rule out my fuel combo as the problem, meth 7 gph 93 plus 10 oz of boostane is what I run all the time. So Wednesday I went down with a can of MS 109 to try with no meth injection this time. Numbers were finally close to what they should be for PBD cal with 22 degrees all in and 3.5" pulley making 15.4 psi. Blue line on the dyno graph was Wednesday with MS109 and it made 794 and 623 TQ. I went back Saturday after burning of the MS109 with my regular mix of meth injection and fuel as stated above and made (red) 782 and 612 TQ. I was happy with the power and likely made by removing 2 1/4" choke point in the Kooks mid pipe ends in my 3" exhaust and taking out the Borla 2.5" resonator and shaping for 3" MBRP resonators. I also did a FORE fuel system and ID 1050's for safety as the fueling was reaching it's limits with the BAP. Strange thing is that peak power was made at 7500 rpm, and I pulled both timed to 8200 rpm. My logs showed boost climbing from 14 psi to 15.5 from that range so boost was not dropping and timing was all in with no knock. This combo should have made power to 8200 rpm, so possible it could have made in the 825 hp range. 24D11313-D553-49B2-B942-DB8F98EE4883.jpeg
    ahl395 and stang17 like this.
  12. Torinate
    Torinate Well-Known Member
    Vehicle(s):
    2016 GT Convertible
    Feb 18, 2018
    Elora Ontario
    689
    149
    Rating:
    100%
    1   0   0
    So what do you think the issue could be why no increase in powers from 7500 to 8200 yet an increase in boost? 800 wheel on real pump gas (non e85 for those of us that can’t get it) is outstanding! 93 with boostane and meth could potentially be available to the masses...
  13. OP
    Roh92cp
    First Name:
    Shawn
    Vehicle(s):
    OW GTPP Whipple
    Jun 27, 2015
    Fort Kent Maine
    2,862
    1,122
    Rating:
    100%
    4   0   0
    Yeah 93 and 10 oz 1/3 bottle in each tank with small shot of meth works. Not sure why is not making power past 7500, I’ll have to send logs to PBD and see that they think.
  14. Boduke0220
    Boduke0220 Well-Known Member
    Vehicle(s):
    2015 GT PP
    Sep 14, 2015
    NC
    615
    194
    0   0   0
    Probably cam timing
    Awesome numbers man, glad you got it sorted out
    Roh92cp likes this.
  15. OP
    Roh92cp
    First Name:
    Shawn
    Vehicle(s):
    OW GTPP Whipple
    Jun 27, 2015
    Fort Kent Maine
    2,862
    1,122
    Rating:
    100%
    4   0   0
    Thanks man, and I'm hoping PBD can adjust cam timing to get it tis make power to 8K. Sure is a relief to know nothing's wrong with the motor or setup.
Loading...
Share This Page
