15 Gen 4 Whipple PBD Cal...What will it make?
Discussion in 'Forced Induction - 5.0L V8 Engine' started by Roh92cp, May 27, 2019.
  1. ahl395
    ahl395 Well-Known Member
    First Name:
    Allan
    Vehicle(s):
    Dec 30, 2015
    2,763
    1,143
    Rating:
    100%
    1   0   0
    Damn, all boxes checked then. Hopefully it's not the motor but I would advise a compression test.
    How do the curves compare? More power in the midrange and then they all stop/flatline at 730? Or is the whole curve nearly identical? Post up the graphs if you can.
    Your timing is on point so I wouldn't expect an issue with spark plugs, but couldnt hurt to check/change them while they're out for the compression test. Maybe something's funky with this dyno and you should try another?
    Burkey likes this.
  2. Burkey
    Burkey Well-Known Member
    Vehicle(s):
    Feb 9, 2016
    Australia
    3,342
    1,745
    Garage Profiles:
    Keen to see the dyno sheet. Could be interesting as @ahl395 alluded to.
  3. OP
    Roh92cp
    Roh92cp Well-Known Member
    First Name:
    Shawn
    Vehicle(s):
    OW GTPP Whipple
    Jun 27, 2015
    Fort Kent Maine
    2,866
    1,124
    Rating:
    100%
    4   0   0
    I'll be doing a compression test soon and will post he logs as well.
    TX-Ripper likes this.
  4. Jay-rod427
    Jay-rod427 Well-Known Member
    Vehicle(s):
    2016 GT C/S
    Jun 8, 2016
    Kansas
    2,351
    926
    Rating:
    100%
    4   0   0
    Agreed what's the rest of the curves look like. A whipple drops efficiency BIG TIME in the upper rpm range. Are you logging boost at all?
  5. OP
    Roh92cp
    First Name:
    Shawn
    Vehicle(s):
    OW GTPP Whipple
    Jun 27, 2015
    Fort Kent Maine
    2,866
    1,124
    Rating:
    100%
    4   0   0
    Yes boost is logged, and I see 15 psi at 8k
  6. Jay-rod427
    Vehicle(s):
    2016 GT C/S
    Jun 8, 2016
    Kansas
    2,351
    926
    Rating:
    100%
    4   0   0
    and intake temperature? Lund told me expect 1% hp drop with every 10 degrees temp goes up. As blower efficiency goes, and pressure rises temp jumps big time.
  7. OP
    Roh92cp
    First Name:
    Shawn
    Vehicle(s):
    OW GTPP Whipple
    Jun 27, 2015
    Fort Kent Maine
    2,866
    1,124
    Rating:
    100%
    4   0   0
    IAT2 is a non issue and not pulling timing on my setup. I have a custom intercooler setup not many have, and my IAT2's were around 95F and no timing was being pulled anyway.
  8. Jay-rod427
    Vehicle(s):
    2016 GT C/S
    Jun 8, 2016
    Kansas
    2,351
    926
    Rating:
    100%
    4   0   0
    Temps can rise without pulling timing. It stayed at 95 the whole pull?
  9. OP
    Roh92cp
    First Name:
    Shawn
    Vehicle(s):
    OW GTPP Whipple
    Jun 27, 2015
    Fort Kent Maine
    2,866
    1,124
    Rating:
    100%
    4   0   0
    Sure I watch IAT's like a hawk and if you saw my setup you would see why I'm obsessed about killing heat. But the logs show IAT2 starting at around 87 F then drooping a bit then rising to 95 wish at the end of the run.
  10. VRP
    VRP Boost Loading...
    First Name:
    Chase
    Vehicle(s):
    2015 GT Premium
    Apr 24, 2016
    Senoia, GA.
    613
    230
    Garage Profiles:
    simple... not enough boost
  11. OP
    Roh92cp
    First Name:
    Shawn
    Vehicle(s):
    OW GTPP Whipple
    Jun 27, 2015
    Fort Kent Maine
    2,866
    1,124
    Rating:
    100%
    4   0   0
    Are you saying 15 psi with 22 timing and 0 knock isn't capable of making 780-800 wheel? or are you saying a 3.5" pulley on a gen 4 at 8100 rpm should make more boost?
  12. VRP
    First Name:
    Chase
    Vehicle(s):
    2015 GT Premium
    Apr 24, 2016
    Senoia, GA.
    613
    230
    Garage Profiles:
    If its in fact peaking 15psi you should be over 800 wheel... Belt slip, bad tune or fuel next issues!
    Stock cats also could be killing a good bit of power actually..
  13. OP
    Roh92cp
    First Name:
    Shawn
    Vehicle(s):
    OW GTPP Whipple
    Jun 27, 2015
    Fort Kent Maine
    2,866
    1,124
    Rating:
    100%
    4   0   0
    Man I'm not sure if you read through my description above, but all those boxes have been checked off already. I'm way past that stuff, but thanks for the input.
    It wouldn't be reaching full timing 22 with 0 knock if it had bad fuel. Dyno didn't show any sign of belt, wheel or clutch clip, and cal is from one of the best Rob at PBD.
  14. markmurfie
    markmurfie Well-Known Member
    First Name:
    Mark
    Vehicle(s):
    2015 Ford Mustang GT
    Jun 6, 2015
    Hawaii
    920
    381
    0   0   0
    Has any other car, recently, made over 730 on that dyno?
  15. OP
    Roh92cp
    First Name:
    Shawn
    Vehicle(s):
    OW GTPP Whipple
    Jun 27, 2015
    Fort Kent Maine
    2,866
    1,124
    Rating:
    100%
    4   0   0
    Cody Batten made 1038 with his stock motor twin turbo June 6.
Loading...
Share This Page
