15 Gen 4 Whipple PBD Cal...What will it make?
Discussion in 'Forced Induction - 5.0L V8 Engine' started by Roh92cp, May 27, 2019.
  1. OP
    Roh92cp
    Roh92cp Well-Known Member
    First Name:
    Shawn
    Vehicle(s):
    OW GTPP Whipple
    Jun 27, 2015
    Fort Kent Maine
    2,866
    1,124
    Rating:
    100%
    4   0   0
    #16 Roh92cp, May 28, 2019
    I've done extensive testing for Jason Etter at Dept Of Boost who fabricated and welded a new plate and 1" inlet outlet into the whipple IC. I have basically have a rolling temp lab with dedicated sensors in the HE outlet (cool side) and the IC outlet (hot side) also have dedicated IAT 2 sensor. The MFP 8mm phenolic spacers made a huge different -30 IAT2.
    Here is the test data below. All done after engine heat soaked then parked and recorded at idle after these times frames sitting. Sorry the data was copy pasted from a word doc that had proper spacing. maybe I can attache the doc.
    Test today April 14, 2019 I added and extended the test to 20 and 25 minutes just to see. Amazing results really.
    44F ambient, last year 43F cart was driven for 30 unites like last time oil temp was 200 and cyl head temp was 201.
    min 0 5 10 15 20 25
    IAT1 50 64 72 72 73 75
    IAT2 90 97 99 100 101 102
    Water Pre 62 73 78 78 78 80
    Water Post 69 80 86 86 86 86
    Below was last fall 43F ambient same cylinder and oil temp as above
    min 0 5 10 15
    IAT1 45 57 66 72
    IAT2 120 133 135 138
    Water Pre 62 73 75 80
    Water Post 65 78 82 86
    Gauge and sensor used for both sides of the water temp.
    https://www.ebay.com/itm/Top-Gauge-Motorcycle-Motorbike-Digital-Water-Temp-Gauge-Red-LED-Waterproof-USA/401433569588?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
    These are the 1” coolant hose adapters for the 1/8” NPT Top Gauge sensor. https://www.ebay.com/itm/30mm-Water...004995&hash=item1a3bf7d464:g:LQoAAOSwzJhZ0UVw
    I have the Zeitronix ZT-2 with their IAT sensor installed in the manifold runner. You can buy one of their many display units or like me I have it displayed through my N-Gauge which is compatible.
    http://www.zeitronix.com/order/order.htm#SECTION_ZT2_BDISPLAY
  2. markmurfie
    markmurfie Well-Known Member
    First Name:
    Mark
    Vehicle(s):
    2015 Ford Mustang GT
    Jun 6, 2015
    Hawaii
    920
    381
    0   0   0
    What water/anti freeze ratio did you have in your system?
    80/20 while not good for winter temps, makes a big difference in the summer, compared to 50/50. Same goes for the engine as well.
  3. OP
    Roh92cp
    First Name:
    Shawn
    Vehicle(s):
    OW GTPP Whipple
    Jun 27, 2015
    Fort Kent Maine
    2,866
    1,124
    Rating:
    100%
    4   0   0
    I live in Northern Maine and need 50/50 water to anti freeze mix.
  4. OP
    Roh92cp
    First Name:
    Shawn
    Vehicle(s):
    OW GTPP Whipple
    Jun 27, 2015
    Fort Kent Maine
    2,866
    1,124
    Rating:
    100%
    4   0   0
    I also have a custom inlet setup with completely sealed Whipple Airbox and dual front feed via fog light and Vellosa Tech big mouth ram air cone inlets. This mod in itself made huge difference in IAT1 when stop and go idle and slow mix ed driving. Here is a little video showing how this setup pulls cool air even at idle from from of the grill at the inlets.
    ahl395 likes this.
  5. Burkey
    Burkey Well-Known Member
    Vehicle(s):
    Feb 9, 2016
    Australia
    3,343
    1,745
    Garage Profiles:
    I like what you’re doing with all that.
    I had mine at the drags over Easter. 90* ambient, couldn’t get the IAT2 under 125* in the almost 2 hours between passes. Hood up, facing into the wind, carefully spraying 50/50 water/alc everywhere....tried everything. Seems to me that once the heat of the engine soaks the lower manifold and IAT2 sensor, you’re gone.
    I expect that phenolics would make a BIG difference in those circumstances.
  6. Tommy V
    Tommy V Well-Known Member
    First Name:
    Tommy
    Vehicle(s):
    Jul 24, 2014
    Brookly park Md
    3,651
    589
    Rating:
    100%
    4   0   0
    Im going to.say 790.
    Roh92cp likes this.
  7. OP
    Roh92cp
    First Name:
    Shawn
    Vehicle(s):
    OW GTPP Whipple
    Jun 27, 2015
    Fort Kent Maine
    2,866
    1,124
    Rating:
    100%
    4   0   0
    Your right the phenolic spacer made a huge difference. I didn't connect the top bolt and have had no ill affects at all. I did measure for stock hood with clay points and it clears by 1/4" at the lowest point. I did however clearance my hood in that area, but in the end don't think that was needed.
  8. ahl395
    ahl395 Well-Known Member
    First Name:
    Allan
    Vehicle(s):
    Dec 30, 2015
    2,763
    1,143
    Rating:
    100%
    1   0   0
    That's some awesome work, I love to see custom done improvements like that.
  9. OP
    Roh92cp
    First Name:
    Shawn
    Vehicle(s):
    OW GTPP Whipple
    Jun 27, 2015
    Fort Kent Maine
    2,866
    1,124
    Rating:
    100%
    4   0   0
    #24 Roh92cp, May 29, 2019
    Thanks man appreciate the kind worlds. I’ve always enjoyed doing crazy shit and differently. This is what happened to my last Mustang a 92 coupe which only had exhaust when I bought it. I did all the work myself and the A2A design as well.
    ahl395 likes this.
  10. OP
    Roh92cp
    First Name:
    Shawn
    Vehicle(s):
    OW GTPP Whipple
    Jun 27, 2015
    Fort Kent Maine
    2,866
    1,124
    Rating:
    100%
    4   0   0
    #25 Roh92cp, Jun 10, 2019
    Mind Blown!!! I'm capped at 730 wheel for some dam reason, figure this one out and winner gets a prize (whine). Dyno'd last Friday 65 F, close to the other dyno days weather in the past and got the same results. All done on the same dyno with same pulley, but many other upgrades for power since the first dyno. Not blaming or shaming anyone here in fact I want to say I've received stellar treatment from Both Rob at PBD and Cody at Batten Motorsports in Bangor, thanks to you guys in advance.
    Oct 2017 Whipple cal Gen 2.5
    stock headers and cats
    3.5" pulley
    93 octane gas
    Meth injection small shot
    7800 rpm pull
    18 total timing
    730 wheel corrected
    A/F 11.8
    April 2019 Whipple Gen 4
    Modified Whipple cal with HP tuners cam timing for power
    Kooks 1 7/8 long tubes No cats
    3.5" pulley
    93 octane with 10 oz boostane
    Meth injection
    7800 rpm pull
    20 timing advance
    729 wheels corrected
    A/F 11.8
    June 2019 same as above except
    PBD Rob cal
    8100 rpm pull
    22 advance timing
    732 wheel corrected
    A/F 11.8
  11. Burkey
    Vehicle(s):
    Feb 9, 2016
    Australia
    3,343
    1,745
    Garage Profiles:
    What diameter is your exhaust system? Specifically, I’m looking at your Borla resonator.
  12. OP
    Roh92cp
    First Name:
    Shawn
    Vehicle(s):
    OW GTPP Whipple
    Jun 27, 2015
    Fort Kent Maine
    2,866
    1,124
    Rating:
    100%
    4   0   0
    All 3” straight through type mufflers and resonator. The Borla Resonator is the 2.25” in 2.5” out. I’m in the process of changing that part to make a true 3” system, but many have made 800 and over with that and similar timing and mods.
  13. ahl395
    First Name:
    Allan
    Vehicle(s):
    Dec 30, 2015
    2,763
    1,143
    Rating:
    100%
    1   0   0
    WTF! That is very disappointing and makes no sense. If it was a different dyno you could easily say dyno variance, but that's not the case here. You've gained literally no power from headers/no cats/more meth/more timing/more RPM. Something is wrong here.
    Are you sure it was revved all the way out on the dyno (hit speed limiter maybe?) And was it dyno'd in 5th?
    Is your clutch slipping?
    Do you have logs of the dyno pulls to make sure it reached full timing? (false knock?)
    Did you pull the fuse or dyno plug in the engine bay?
    Same correction used each time?
    I hate to even suggest this, but have you done a compression test?
    I feel your pain a little bit. My last dyno showed I gained a whole 50hp from +3psi, +3deg, cat delete, MAK inlet, and meth injection entirely. But it was a different dyno so I have that to blame. Your case is much different.
  14. Burkey
    Vehicle(s):
    Feb 9, 2016
    Australia
    3,343
    1,745
    Garage Profiles:
    Honestly, I see NA cars profiting from removal of that 2.25” bottleneck ALL the time.
    I can’t see how that isn’t hurting your setup.
    Let us know how you get on with it.
    Cheers
    Roh92cp likes this.
  15. OP
    Roh92cp
    First Name:
    Shawn
    Vehicle(s):
    OW GTPP Whipple
    Jun 27, 2015
    Fort Kent Maine
    2,866
    1,124
    Rating:
    100%
    4   0   0
    The car feels faster especially on the initial hit driving and really seems to pull hard AF, but it's not showing for sure and it should. As far as the reasons why we scratched our heads and double checked everything, between me Rob and Cody Batten we looked at everything we could. I'm also wondering now of it's the motor.
    1. All runs were data logged and reviewed by us and Rob at PBD
    2. No wheel or clutch slip showed on the dyno
    3. Verified all runs to 8100
    4. full timing verified
    5. Same correction standard smoothing 5
    6. Yes advance track was disabled via the connection next to the airbox.
    ahl395 likes this.
Loading...
Share This Page
