Mootang
- Oct 2, 2016
- Sacto, Caliunicornia
- Henry
- 2017 Mustang GT
Only thing I would be concern about is how to connect it right. That harness has a purple wire coming out and that connects with the purple wire from their turn signal. If you can figure that out, then it may work with the Opt7Reading what it says at CJPP, it just makes it so the turn signals are on with drl's...when you turn and activate, they fade and go into blink mode. Paraphrasing..."optional wiring harness to use the DRL input wire to connect directly into your OE headlight wiring harness. This means that the upgraded LED turn signals will also have full-time Daytime Running Light functionality--the bright white LEDs will be on like regular running lights, but will dim when the turn signal and the amber LEDs are engaged." So I'm thinking they will do the same for the OPT7's. From OPT7...The OPT7 Mustang Arrow lights function as white DRLs in the following scenarios:
When your headlights are switched on.
When your lights are set to Parking mode.
Which means you have to have your lights on, hence why I'm thinking get the harness so I can have them as drl's as well.
