10HP Loss, Not compression! Real reason exposed with Dyno Proof
VelR5.0GT
IL
2016 F150 5.0, 2022 Mustang GT
So I got a hold of a ‘19 GT air filter box and tube that my buddy had sitting around. I’ve been curious about the inner diameter tube size since the ‘19 doesn’t have the carbon trap/bracket/housing and honeycomb insert and the ‘22 does. Well I measured the inside diameter of the insert on my ‘22 and it measured 96.6mm and the ‘19 without it measured 98-99mm. Just like I suspected. The ‘22 definitely has some airflow restrictions in the form of carbon trap and its housing and the honeycomb insert. The honeycomb alone with the “thick” squares and smaller diameter should reduce the airflow. It may not be something gigantic but I bet is measurable on a cfm machine.
Rael
Grateful Member
South California
2022 Mach 1
I just removed the hydrocarbon trap in the Mach 1. Have to wait until tomorrow to see if I notice a difference.
wile e coyote
N.H
Joseph
2014 Audi A6 TDI Soon to be 2022 Mach 1
If you remove the hydrocarbon trap the tube needs to be put back in for the diameter of the tube for the sensor to measure. IF you don't the sensor is now not calibrated and possibly more fuel will be dumped.
Rael
Grateful Member
South California
2022 Mach 1
Ooh, maybe that's why I think I'm hearing a little bit of backfire now and then.
Thanks.
Connecticut
Tom
2021 Premium,10spd,3:55s,Ford Power pack 2 tune
Connecticut
Tom
Ford lowered the compression from 12 to 1 ,down to 11 to 1, that dumb trap is not giving you 10 horsepower, SMH
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Connecticut
Tom
You don't have a typo on the Ford web page ,You don't have a typo on their web page, they would have changed it if it was wrong, SMH. .. the 22 guys are in Big Time denial with the horsepower drop, guys are a bunch of knuckleheads if you think the filter does anything for horsepower. .... whatever, all my s*** works.
K4fxd
NKY
I thought eariler in this thread it was proven that the comp ratio stayed at 12. Not sure how accurate the link is but this is from it.
Updated on 10/13/2021 at 3:15 p.m. ET: When asked what exactly was changed on the engine to meet these requirements, a Ford spokesperson clarified, “For 2022, the Mustang’s 5.0-liter V8 engine’s hydrocarbon traps were modified, with a new mass airflow sensor location and updated engine calibration.”
https://www.thedrive.com/news/42730...-0l-v8-down-10-hp-to-meet-emissions-standards
Coastal-Mach
Wilmington, NC
Anthony
2023 BMW M440i, 2020 Ram 1500, 2021 Jeep JK
It looks like they changed it. Below is a copy of the 2021& 2022 engine specs. You will see, the HP loss of 10 but the compression is the same.
As you can see it’s from Ford, do I care about the 10 HP loss not really but in the Mach 1 the HC filter removal makes a difference as it is located in the intake tube behind the MAF.
More air in equals HP, a non restrictive paths will always perform better. No denial, I could care less what’s on paper. Welcome to the forum by the way.
Connecticut
Tom
That is clearly a outdated page you are showing, Ford markets the new 5.0 at 11:00 to 1 compression... it's on their current specifications page it's even in the Mustang brochures specifications, Mach 1 and GT have 11 to 1 for the 22 model year and that's straight from Ford... 22 Mustang guys are in total denial.
K4fxd
NKY
Post a link
Coastal-Mach
Wilmington, NC
Anthony
Bro, I went to the Ford Website minutes ago and screenshot the page. Again no denial, just trying to correct your statement with facts from Ford.
