10HP Loss, Not compression! Real reason exposed with Dyno Proof
steathv
Lynchburg, VA
2022 California Special
When you say the MAF tube diameters are the same between the '22 and '21, did you actually measure the inside diameter? I am curious due to the insert (airflow straightener). A few millimeters between the two can throw off the MAF readings against the calibration.
There does not appear to be an insert for the straightener it is built into the tube wall or pressed in.
VelR5.0GT
IL
2016 F150 5.0, 2022 Mustang GT
There is one. Just like the Mach 1. Another member took it off on his but his car was already tuned and still acted funny.
Dfeeds
Illinois, US
Then there’s this: (see post #2)
https://www.mustang6g.com/forums/th...ut-the-2022-having-less-hp-and-torque.179646/
Kinda makes you want to say “ok, maybe but so what?”
On the other hand it does kinda beg the question if a stock 22 runs pretty much the same as a stock 21, if you lose the 22’s HC filter will it then be stronger than a stock 21?
Stranger things have happened. And far as I can tell, the post above is the closest thing we’ve seen so far to someone actually timing a 22 on the strip.
Driver skill and DA would affect the time more than that 10 hp ever would. Hell, the driver's weight would be a more significant factor than the 10 hp difference.
To that extent (and per your question), in a vacuum, if the 21 MY runs .1 sec faster than the 22 MY due to the 10 hp, logic would dictate that an increase of 10 hp for the 22 is only good for one tenth of a second.
Bikeman315
Myrtle Beach, SC
Ira
Oh no, you used the “l” word. You may get banned for that! :cwl: :crackup: :like:
2022 Mach 1
Brentwood ca
Cameron
2022 Mach 1...2014 Mustag GT whipple supercharger
Fresh of the street legal drags last night. Track had very little prep. There easily a 10th I left in the first 60 and probably 2 the by the end if I improve to a 1.8x 60ft
This is drag mode nannies off. Leaving of idle. Car 100% stock including the HC trap in place.
steathv
Lynchburg, VA
I have looked at the air straightner more closely and it is built into the tube and is not an insert. I have driven the car for 75 miles at all sorts of rpms and pulls and monitored the air fuel ratio and the ratio shows nothing abnormal.
merlin803
MI
clay
2023 Mach 1 P0004
Only two days of driving after my filter went missing and no problems.
I did see something that I wasn't expecting, and maybe it's just a huge coincidence but I reset my MPG counter before going to work this morning (same stop & go city driving route as every day and same semi-heavy acceleration - if anything, heavier than normal just to see if there were any unwanted side effects....) and I get home and check the results and was at 21.7 MPG!.
For the past 6 months, I was averaging about 19.4 on my daily driving.
Like I said, may be a coincidence but just thought it was interesting. In any case, the MPG certainly didn't get worse.
young at heart
Deep South
20 GT vert A10 / 23 Mach 1 A10 / 23 Mach 1 Tremec
This air straightener you guys are talking about; is it on the 22 Mach 1 or the regular GT? If it’s the GT, can you describe it a little more for me or maybe point me to a pic?
Thanks!
steathv
Lynchburg, VA
Thanks!
The GT is what I am referring to.
tuf50L
Australia
Order pending
Can you replace the ‘22 GT air box with the M1 air box and connect it up to the original GT intake tube?
I know it’s not a free mod then but still.
VelR5.0GT
IL
There is one. Look into this threads and pictures: https://www.mustang6g.com/forums/threads/look-what-i-discovered-in-my-22-🤨.179049/
I'm glad that you are not noticing anything crazy, but keep in mind that you don't want your fuel trims to be on the high side because it leaves very little compensation.
VelR5.0GT
IL
I'm sure that removing any airflow restriction in the air intake side will show better mpg. There are 3 things with the "22+ carbon trap that I noticed that will decrease airflow. Not only the carbon trap, but the housing is smaller (area) that even the actual engine air filer. This not even counting the bracing on both sides of the carbon trap, and finally the insert which decreases some of the tube inner diameter (maybe 1-2mm) combined with the honeycomb that once you look closely the squares inside are actually fairly thick. I am sure the honeycomb was added for a laminar airflow over the MAF sensor due to the carbon trap/bracing creating turbulence.
It would be great to see both air intakes from the air filter lid to the connection of the throttle body from a '18 to '21 and a '22 placed on a CFM machine to show the differences. I'm sure the "22 will show a measurable decrease in airflow.
Hifiguy
Mach 1 Mustang
So I just got done removing the carbon trap off my Mach 1, kept the inner tube.
Why is the intake path different on the GT?
On the mach 1 it's:
Intake filter -> MAF -> Carbon Trap -> throttle body
And from what I understand on the GT:
Intake filter -> Carbon Trap -> Honeycomb grid -> MAF -> throttle body
Why does the Mach 1 not have a honeycomb filter? Is it because the carbon trap is after (downstream) the MAF thus not affecting laminar airflow across the MAF? Consequently, wouldn't MAF scaling be off a little when taking out the carbon trap in the Mach 1 but leaving the inner tube? or is MAF scaling not affected by downstream elements?
So if you remove the carbon trap from the GT, will the MAF readings be slightly off since the filter is upstream? Or is this what the honeycomb filter helps with?
tuf50L
Australia
Order pending
On the mach 1 it's:
I was looking to cobble together an OEM intake to eliminate all the carbon traps on a '22 GT using the GT intake tube and Mach 1 airbox.
However, as you say the configuration is slightly different.
