TKO Performance
- Apr 21, 2017
- LI NY
- Website
- www.tkoperformance.com
- 2014 Corvette
10% coupon in place Just type in " mustang6g " (No caps no space no quotes)
Reduce interior noise in SECONDS
The Blockit is placed right over your existing factory trunk carpet. Its pre cut to fit perfect. Installation is about 60 seconds.
The Blockit is designed to take the edge off road & tire noise (which is brutal in certain states) & help with some aftermarket exhaust. Not to worry, your sweet exhaust note will still come through when you get on it!
We are getting feedback that it also helps quiet down certain suspension "clunking" type noises too.
Each mat is 1" thick and its patent pending design is made up of 4 layers of real acoustical materials which absorb & suppress irritating sounds. The layers are held together by a unique infusing method to insure it will not separate plus there is no toxic glue.
What’s nice is you are not gluing down permanent weight. The mat weighs approx 17 lb but if you’re going to the track simply take it out! Reinstall for the ride home.
The BLOCKIT ™ also helps cut back on heat to help keep your trunk cooler.
The durable top textured layer allows you to still use your truck for storage. However, you can place a factory mat or aftermarket mat on top if you like.
Fits both with and without the factory sub woofer. Cars with the factory sub woofer remove the detachable piece
Made in the USA!
So efficient we filed for a patent
The small piece on the right gets removed if you have a factory Subwoofer.
Perfect fit!
★To Order Click Here:
http://www.tkoperformance.com/2015-2018-Mustang-Blockit-Quick-Quiet-Mat_p_2008.html
10% coupon in place
All made in the USA.
All raw materials are from the USA!
4 layers of REAL automotive grade acoustical soundproofing materials - FMVSS-302 Tested & approved!
Manufactured under strict ISO 9001 regulations.
If you have any questions, please feel free to contact us 1800 778 9898
Thank you!
Ed
