RPI Designs 2015 Ford Mustang HALO LED Headlight Rings and Strips - ColorSHIFT
RPIDON
Salem, OH
Mustang
Item # FO-MU15CS-RGB $435.00
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=5132
Looking for a great way to set your 2015 Ford Mustang apart from the crowd? Our 2015 Ford Mustang LED HALO Headlight Rings and strips are the way to accomplish that goal. These rings are sold as a set of two and come in a variety of color choices. The LED lights are bright and sure to catch attention!
The latest version of the ORACLE ColorSHIFT Halos features High-Powered 5050 RGB 3-Chip LEDs electro-soldered with computer accuracy to a 6-Layer Rigid PCB. This new version delivers brighter and more fluid light output than the original ColorSHIFT rings. Each 5050 Surface Mounted Diode contains three 3528 LEDs (making each LED 3x brighter than the LEDs on previous rings) one Red, one Blue, and one Green diode in each LED. This allow you to make consistent colors such as "pure" white without seeing the individual colored LEDs on the ring. This type of 5050 3-Chip LED is a high-quality SMD with a 50,000 Hour Lifetime Rating that has proven to work extremely in this application during our testing.
This kit will fit all 2015 Ford Mustang Models.
Kit includes the following:
• 2 x 2015 Ford Mustang ORACLE ColorSHIFT LED Halo Rings
• 6 x ORACLE 4" Concept 5050 SMD Strips
• 1 x ORACLE ColorSHIFT 2.0 Controller with Wireless Remote
• DIY Installation Instruction Guide
• Everything you need to add ORACLE ColorSHIFT Halos and ORACLE Concept DRLs to your Headlights!
ORACLE Concept 5050 RGB Strips Features:
• 12 Volt Powered
• Low Heat Output
• Thicker PCB board makes the strips easier to bend and mold into shapes.
• Each strip uses Bridgelux 5050 RGB SMD chips(Made in the U.S.A.)
• Can produce many thousands of color hues with the use of a ColorSHIFT RGB Controller
ORACLE ColorSHIFT 2.0 Wireless Controller Features:
Our new ColorSHIFT 2.0 LED Controller has several advantages over the previous version. This new controller can be programmed by the operator for an almost endless number of colors and functions that the user can design and save on the units memory. Another major change to this new unit is that the box itself has a controller as well as a wireless infrared remote control. There is also a LED indicator on the unit that shows the operator what color the LEDs are set on at that time. Our new 2.0 controller also has twice the output and expandability as the previous version with 15A capacity which can power twice as many lights from this single box.
yessirrom
DFW Texas
2017 Magnetic GT Convertible
Video?
RPIDON
Salem, OH
Mustang
The manufacture does not have a current video of the installation process for the 2015 Mustang, here is a video of the 2010-2014 Mustang cars, the process will be very similar. [ame="[MEDIA=youtube]1SAm95x-IZo[/MEDIA]"][/ame]
SheStang
AL
'16 GT Oxford White
Hello,
Any pictures or videos of these installed yet?
Thanks.
RPIDON
Salem, OH
Mustang
A great way to make your headlights stand out from the crowd and give it that sinister look!! .
Asonitez
I go 71 in a 70 *REBEL*
North Carolina
Tristian
2016 Oxford White GT Premium
How much to make you guys do the install?
RPI Designs
Salem, Ohio
www.rpidesigns.com
2015 Mustang GT - Test Mule
