olaosunt
So, my stock compression alluminator let go last week.
Long story but I have already gone in to the details on my other thread.
I am looking at options for an engine replacement and almost pulled the trigger(I actually did but credit card payment did not go through despite adequate funds in my "mod saving account" which may be a sign!) on a 5.2 sleeved block I was going to pair with GT 350 heads I can get for a relative deal.
One of my other "mod" funds recently got discovered by "Wife-eye" (warning radius not limited like wifi)so I was kind of eager to use this other fund before it also got busted.lol
I had also previously (before blown motor) considered a GT 350 engine swap but talked myself out of it knowing I would never be able to run much boost as I was still chasing 9's. However since Hellion announced the first TT GT 350 I am again giving it serious consideration
Since I almost pulled the trigger there have been some life changing events and I now really need to consider buying my daughter a safe 4 wheel drive so may need to consider a cheaper option to replace the engine.
Let’s just say one of my favorite cars is most likely going to be totaled (I thank God she is safe) and I have no intention of replacing it with a similar premium car.
I have gone over the pros and cons of a GT 350 engine vs sleeved block so many times in my head but here it is on paper. As you will see the pros and overwhelmingly in favor of the GT 350 engine
GT350 engine.
Pros-I don't feel I need to make as much power as I did before and if I can run 10's on a safe tune and low boost level I may be happy.
I already reached my drag racing goal of mid 9’s @140's for the car and have already been asked to slow down or not run again at the closest and my favorite track in Indy. I can run the car at a couple of other tracks without the required roll cage but they are several hours away. To be honest I have felt quite uneasy the last few passes I made knowing I don't have the recommended (for good reason) safety gear for the speed I was going. I don't do any competitive drag racing (just a test and tuner/collector of bragging rights! lol) so have no intention of putting a cage in the car. I certainly have no intention of shooting for an 8 second pass so a sleeved block may be overkill.
I already have a GT350, which makes the most glorious sound, is fast enough for the street but I have wondered if it would be even more fun with a little bit of boost. I am not a 100 % sure it needs it but this would be a fun way to find out. Having a N/A aspirated manual GT350 and Hellion boosted auto GT with a Voodoo would be kind of be like having your cake and eating it
I was never impressed with the exhaust note of my Hellion car and if it would still sound a little like the GT 350(I expect the turbo's will muffle the sound a bit) with the same engine that would be the icing on the cake
The GT350 engine is fully dressed and available compared to the 4-6 weeks I am told it will take to build the 5.2.I would have to use engine components from my alluminator to complete that build but with the GT 350 engine, I could potentially repair the alluminator (swap in better pistons) for relatively cheap and have a complete dressed engine I could sell towards the cost of the GT350 engine or keep as a “spare" for if I really felt the need to turn up the boost again(hopefully with the Voodoo still intact)
Finally if I ever decided to sell the car, I think it may increase its value as compared to having a rebuilt alluminator or even a sleeved 5.2(which may be limited to a drag racing crowd).
I doubt there are going to be many more Voodoo swapped cars especially since the crate motor is not available for sale(don’t ask me how I can get one).
I can also confirm there will be no more Voodoo engines built after the 2017 GT 350.
The cons:
I won’t be able to turn up the boost or go as fast (unless I swap in the alluminator again).
Only God know how much boost is "safe".
Hellion said they needed to make changes to GT kit fit the GT 350.I have wondered how they would tap the oil pain since it is lightweight plastic on the GT350.
Tuning-As we all know the GT 350 engine has a different firing order. My tuner thinks it doable to keep the GT ECU and make changes to the tune so it will run.
I would hate to do the swap and then not be able to have it tuned,
The GT350 engine and the 5.2 sleeved engine build (including the heads) will cost roughly the same with slightly less labor for the complete engine install.
Alternatively I could just choose option 3 and simply rebuild my alluminator for 1/10 th of the price of option 1 and 2.
I could use better pistons (2618) and use sleeve supports.
I know some here feel they are like snake oil but for the price, worth a try in case they do work.
I would of course keep the boost down(I may not need as much since I will finally get to use the MMR valve springs I bought months ago).
Funny thing is with my buddy's help I could rebuild that engine including R&R /upgrading the valve springs for not much more than I was about to pay to have the springs installed with the engine in the car
I know this is a LONG read, so If you took the time, THANKS.
I am really looking for some other opinions, perspective and especially any potential pitfalls with the GT350 engine I may have overlooked (other than “dude that engine was not meant to be boosted”) lol.
I still suspect tuning may be an issue .
GT350 engine.
The cons:
