auj4
- Apr 19, 2017
- Sydney, Aus
- MY17 GT FB GB
Dr. Colorchip is your friend.Got another stone chip. This paint is so thin
It looks easy to use. Would you recommend it?Dr. Colorchip is your friend.
That’s for sure. I have been using it to great effectDr. Colorchip is your friend.
It's the best (non-professional) option out there by a long shot.It looks easy to use. Would you recommend it?
Didn't feel the alignment sleeves were causing any problems and the jiggling was just that - no major shoving. Of the four big blue bolts (that you don't want to cross thread) it was only the front passenger one that was more difficult to get in.Nice work Michael, I've got the same coming for my car as well as SP089/82. Clearly great minds are at work.
I understood the CB005 - among other things - aligned the cradle. Was the jiggling required because the sub frame alignment kit was fighting with the CB005 about which was the more correct location, or was the alignment kit just creating a bit of interference?
Cheers
Yes they intro'd the kit just as I was buying mine but Summit didn't stock it. Good to know the ride is ok I'm tenuous about the springs in terms of comfort but the minimal increase in rate and drop was what persuaded me to give them a go. If they're not as comfortable as the stockers they may well come off, but I'll do the mounts first and then the springs.Really like these springs (SP089/82). I've had them in over 15 months now and couldn't be happier with the stance whilst still practical and the handling whilst still comfortable. I see BMR do them as a specific kit now.
The springs are great, seriously. Once they're on, you won't be taking them off again. Very comfortable with a perfect stance.Yes they intro'd the kit just as I was buying mine but Summit didn't stock it. Good to know the ride is ok I'm tenuous about the springs in terms of comfort but the minimal increase in rate and drop was what persuaded me to give them a go. If they're not as comfortable as the stockers they may well come off, but I'll do the mounts first and then the springs.
Are you comtemplating the RLCA bushings and vertical links? I'm favouring the RLCA ahead of the vertical links in the order of things.
